D Stock GS vs. STX?
Looks good, I might go a little more aggressive on the toe out on front, but, thats just me, maybe 1/8" or so, but your Mini might dance around a bit more with normal street driving if you hit a bump. On the rear, try to dial out as much camber as possible(-.8 to -1.2 or so) and make sure they are more or less even from left/Right. On the Front, make sure everything is even there as well, if not, the subframe could be slightly out of alignment and would need re-aligning, thats a common problem.
Are you trying to have ultimate fun in your MINI or be seriously competitive? If the former, and you want to mod then go STX (remember there are some mods that will take you out of STX, a pulley for example). There is an STX driver in the DC region that fares well but generally the MINI is not the car in STX.
If you want to compete for first place then try G stock.
Originally Posted by bobdobbs
Sorry for the noob question, but I've just recently started to run my '06 MCS in Solo2 and I'm trying to decide in which class to run it. I want to be able to do mods, and running street tires is appealing but is the MCS out-classed in STX? It seems to do much better in GS. Is this simply because there are more running in GS, or do we have a disadvantage running in STX?
Thanks much!
Thanks much!
Originally Posted by Bluegarvis
No sweat... just checking to make sure. So, here is my plan after being away from auto-x for a long time... what do you think? I will run this for the rest of this year, doing more mods as my wallet allows and my times improve...
Falken RT-615 205/40/16 on my old stock x-lites
Aligment to 1/16 toe out front, 0 negative camber rear
Scroth Harness
Replacement air filter
Milltek or custom cat back (time and money permitting)
Thanks to all for the assistance this forum has provided...
Garth
Scroth Harness
Garth
Drivetrain Helix | F56 Intercooler Testing
Helix13mini
Jul 27, 2016 06:29 PM
mbatech
Sep 10, 2015 03:40 PM
