Solo Help for Solo II Alignment pre '04 MCS suspension
Old Mar 22, 2006 | 12:44 PM
Montana Miniac's Avatar
Montana Miniac
Tomorrow I have a appointment for wheel alignment on my '02 MCS. This car doubles as a daily driver as well as a weekend warrior. From what I have heard, the camber is not adjustable. Recommendations have leaned to wards a Toe setting of 1/16 (out) for the front, & 1/16 (in) for the rear. I will be using BFG G Force TA KDW2 tires on Pro Race II 17" rims. Do the specs for toe settings sound correct & is there pressure recommendation to start with, using 17" tires. ( I know 17 ain't the first choice, but thats what I got & there is very little info out there).
Thanks in advance.
Old Mar 22, 2006 | 01:17 PM
gowest's Avatar
gowest
Unless you have a larger rear sway bar I think you'll be better off with 0 rear toe, to help rotation. Higher or lower rear pressures, than normal, will help rotation also.
Old Mar 22, 2006 | 02:03 PM
scobib's Avatar
scobib
I agree... toe out in front, 0 toe in rear...
Old Mar 22, 2006 | 05:25 PM
JustGo4It_'s Avatar
JustGo4It_
In the front I'm running 1/16 out each side for a total of 1/8th.
In the rear I've got 1/16 out total.
Stock rear bar.
Car is a daily driver.
Old Mar 22, 2006 | 06:26 PM
Montana Miniac
Thanks for the suspension info. Anyone out there running on sticky non run flat 17" tires that can offer some pressures?
Old Mar 22, 2006 | 10:20 PM
Miniwildcat's Avatar
Miniwildcat
I ran my BFG KDW2's at Carolina MOtorsports Park last year. The pressures I was using were 42 front and 38 rear if I recall. I torn the hell out of the fronts though so be warned, no front camber is murder on the tires. Keep in mind, that was a track day not an autocross so pressures may or may not be very useful. It is a place to start at least.
Old Mar 24, 2006 | 06:17 AM
Montana Miniac
Thanks all for your help. I know this topic has been beaten to death, but I was unsure if the discussion included the 'older' style suspensions. I set the front end toe at -.05 on each side for a total of -.10 out. (I'm lousy with math 1/10th" ?). I will have to track the car, but it seems to work well on the road.I was going for a multi purpose setting here.There was absolutely no adjustment to be had in caster & camber. I tried loosening the strut towers to no avail. Of course, as expected, there was no adjustment (including toe) in the rear suspension ether. This is what I ended up with:
Front: caster 4.2 & 3.8 rear:
camber 0.4 & 0.9 camber 1.8 & 1.4
toe -0.05 & 0.05 (total -.10) toe .10 & .05 (total.15)
I'm new at this, and don't know this alignment shop. Are we in the ball park here? Your comments appreciated. Thanks.
Old Mar 24, 2006 | 10:31 AM
gowest's Avatar
gowest
Rear toe is adjustable, if you requested a specific number go back and tell them to do it again. It requires the loosening of THREE bolts (one hidden by a plastic flap) at the front end of each trailing arm and a means of sliding the arm in or out.
You can even out the front camber by loosening the subframe bolts and sliding that in the desired direction. I'd want the dealer to do that or a trusted alignment shop.
You also sound uncertain of the measurments. It will be in degrees or inches. If it's in inches, get rear done again. If it's in degrees then the rear really isn't so far off zero as I'd consider it important to go back for that but then the front really wouldn't be where you want it if it's -.10 degree.
Old Apr 3, 2006 | 12:01 PM
Montana Miniac
These would be cold pressures?
Old Apr 3, 2006 | 10:05 PM
AZLarryB's Avatar
AZLarryB
I'd highly recommend picking up the April GrassRoots Motorsports issue. They have an extended article on setting up their MINI for autocross. It's a pretty comprehensive write-up; shocks, tires, wheels, alignment, etc etc etc. They cover stock class, some beyond stock info, and even "what if I want to...." stuff. Good info from some serious racers.
eatsleepautox
Oct 30, 2015 06:46 AM
maestro39
Oct 27, 2015 02:38 PM
Minibeagle
Aug 13, 2015 10:00 AM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
