D Stock Koni install help
Old Nov 25, 2007 | 12:22 PM
ken o's Avatar
ken o
Koni install help
I just got my DA Konis in. Trying to install the rears and notice the shaft is bigger than the OEM shaft. Is this normal? I sent donor shocks for the bottom mount. Were your Konis made with the larger upper shaft? If so what did you use for the washer under the top mount and for the spacer in the bushing above the top mount?
Ken
Old Nov 25, 2007 | 04:43 PM
Motoring's Avatar
Motoring
Yes that is normal. You have to enlarge the hole in the washer and the top mount. Say hello to Mr. Dremel.
Old Nov 25, 2007 | 05:58 PM
ken o's Avatar
ken o
Thanks. What about the spacer or sleeve? Enlarging it leaves 2mm.
Old Nov 25, 2007 | 08:54 PM
Motoring's Avatar
Motoring
The sleeve still fit on mine
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
