Running issues multiple codes
Old Nov 13, 2019 | 06:50 PM
Jeff k's Avatar
Jeff k
Hello, I’ve been directed here to the gurus of mini, I have an issue and I need help pinning it all down. I have a 2011 Mini Cooper countryman s all4 just rebuilt their motor. Had an issue with it wanting to start then die finally had multiple codes code come up. I could clear them and different ones would come back fixed the issue with a ground wire on the valve cover.
new issues
Alright new issue....
Codes I am getting
P16e7
P0324
P10ed
Po53a
Car was running fine then started all this.....
I drove the car out of the shop it was running for about 20 mins dueling quietly now I have no gas pedal can’t drive it but when it’s idle if it sounds alright aside from the noisy valvetrain. I checked the timing on everything and compression again and it is all spot on!
I am very very lost here because the only different I can find between now and before the rebuild is is running on all 4 cylinders..
please help thanks in advance!
Old Nov 19, 2019 | 12:56 PM
Jeff k's Avatar
Jeff k
Code p16e7 comes on immediately after clearing the codes as soon as the ignition is on its back instantly does anybody have a wiring diagram for this circuit?
Old Nov 19, 2019 | 04:43 PM
mikey_t's Avatar
mikey_t
Try this site: https://www.newtis.info/tisv2/a/en/r60-cooper-sav/
Old Nov 19, 2019 | 07:14 PM
Jeff k's Avatar
Jeff k
Originally Posted by mikey_t
thank you!
KSutherland
Jul 17, 2018 03:09 PM
turbo224
Nov 25, 2015 10:02 AM
a2oc
May 8, 2015 03:28 PM
usafdrew
Apr 14, 2013 11:30 AM
big gunnie
Apr 12, 2010 06:20 PM
