R60 Rear lower control arm ball joint?
Old Mar 27, 2023 | 05:11 PM
MiniMadLove's Avatar
MiniMadLove
I know this is a dumb question, but I'm wanting to replace my rear lower control arms on my 2013 countryman S, and I am trying to find adjustable arms with ball joints included already... but the more I research, the more confused I become. Are there ball joints in the rear lower control arms? If there are, can I replace the control arms (easily) without having to replace the joints?
Old Mar 28, 2023 | 08:27 AM
Hello,
Which ones are you changing?
Front lower control arms. Diagram: https://www.realoem.com/bmw/enUS/sho...11#31129806520
https://www.ecstuning.com/Mini-2013-...rol_Arm/Front/
Rear control amrs on the rear suspension. Diagram: https://www.realoem.com/bmw/enUS/sho...diagId=33_1560
https://www.ecstuning.com/Mini-2013-...trol_Arm/Rear/
Old Mar 28, 2023 | 08:35 AM
MiniMadLove
Hi,
Changing #9 on this diagram, wishbone lower. I have a bad negative camber, need to switch from stock to adjustable camber arm. I haven't been able to find any videos on my specific model, mostly awd and a few older model fwd.
Old Mar 28, 2023 | 08:52 AM
#9 is those adjustable arms we carry (shared on the R56 MINI Cooper), you just do the lower ones on each side. Its the same as the R56 MINI. Just little bigger trailing arm and a four wheel drive set up (if you have it) . Linked above. That's and # 6 to the body connection are the rear alignment adjustments. Get those lower links and but it on an alignment rack and have it aligned to the set up you want. # 9 in adjustable format (over stock solid bar) gets you more adjustment in or out on the lower portion.
Old Mar 28, 2023 | 08:54 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Those rear control arms will swap out the same as the R56, so you can follow those tutorials.
There are no ball joints in that process either. One bolt on each end, drop, and reinstall.
Make sure you mark the orientation of the alignment bolt at the rear knuckle before loosening. Than you can reinstall to the same location. Also, get the adjustable arm as close as possible to the same length as the OEM control arm. If you are diligent with these two steps, the car will drive the same as OEM configuration until you can get into the alignment shop.
Old Mar 30, 2023 | 10:07 AM
MiniMadLove
Thank you so much for the help!
I'm glad to know I don't have to worry about joints on this.
Old May 28, 2023 | 03:07 PM
Polytones's Avatar
Polytones
I'm going to have Eibach Pro Kit springs installed on my R60 and it's my understanding I'll need rear control arms to adjust the camber aftward. Wondering which rear control arms to buy.
Godspeed are about $150
Meghan Racing are about $225
H-Sport are about $315
NM are about $440
I can't really find any reviews of any of them other than the H-Sport. Thanks for any help/info you can provide.
Old May 29, 2023 | 03:35 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
NM are about $440
For a daily driver, just get the inexpensive Dorman adjustable from RockAuto. If you plan on driving hard, get the H-Sports. Stay away from anything with a metal ball joint on the end. Those are high maintenance joints and will make a lot of noises.
Old May 31, 2023 | 05:33 PM
MiniMadLove
Hi,
I'm mostly a daily driver/roadtripper and when I replaced my rear lower control arms a few months back I put on a pair from Mevotech, from parts geek. (SKU #GK100003) They were $210, and they had a farily wide range of adjustment. I like them a lot, I haven't noticed any problems and they were really easy to put on. I didn't really need help for any part of it.
Old Jun 1, 2023 | 03:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Originally Posted by MiniMadLove
Hi,
$103 on RockAuto:
https://www.rockauto.com/en/moreinfo...enpPr1iV9d81l1
notthemaniusedtobe
Apr 6, 2018 04:39 AM
DaveBri
Suspension
Jun 2, 2014 06:35 PM
heyjae
Suspension
12
Mar 16, 2009 07:22 PM
Electron_Mike
Suspension
Apr 22, 2006 12:25 PM
dpayne1
SCCA Solo and ProSolo
Feb 2, 2006 08:25 PM
