Drivetrain Oxspeed BOV spring
Old Jul 16, 2012 | 04:13 PM
  #26
JohnJohn's Avatar
JohnJohn
Got mine today. I'm not sure how any of you got in there to get the BOV out? On my 2012 CM S there is a hard coolant, or oil return line running right over the top of it. I can't get my allen sockets or even an allen wrench on all three screws.
Old Jul 16, 2012 | 04:17 PM
  #27
kconner5's Avatar
kconner5
Just got mine and I'm going to attempt installation
Kyle
Old Jul 16, 2012 | 04:19 PM
  #28
Mical's Avatar
Mical
With a large straight blade screwdriver you can can pry that line to either side to access allen screws. It moves pretty easily and doesn't need alot of pressure to move it. Had to do it on mine also to access lower rear allen screw.
Old Jul 16, 2012 | 04:26 PM
  #29
JohnJohn's Avatar
JohnJohn
Thanks, I'll let it cool off a little more and give that a whirl.
Old Jul 16, 2012 | 04:34 PM
  #30
chrunck's Avatar
chrunck
Got mine today as well. I'll probably give it a shot this weekend, if I can wait that long.
Edit: Not too impressed with the packaging. They were just taped to a letter inside an envelope that looked like it had a rough time through the mail sorter at the post office. I ordered 2 springs and they don't look identical by a long shot.
Old Jul 16, 2012 | 05:41 PM
  #31
kconner5's Avatar
kconner5
Stupid question... How do I get the turbo inlet tube off?
Kyle
Old Jul 16, 2012 | 05:47 PM
  #32
Mical's Avatar
Mical
Kyle
Not a stupid question... undo clamp at turbo (cool of course) and pry towards driver headlamp. You might use a long staright blade screwdriver to help get started.
Old Jul 16, 2012 | 05:49 PM
  #33
kconner5's Avatar
kconner5
Ok, wasnt sure about the prying part. I'm sure I'll have more questions, thanks!!!
Kyle
Old Jul 16, 2012 | 06:21 PM
  #34
Bmtespar's Avatar
Bmtespar
Got mine today and installed it. It was a pain In the **** to get to. I removed the air tube, the coolant tank and then unbolted the mount we're the metal line comes down. Judging by the pics on the alta install PDF, that coolant line comes down further in the r60. It took some finessing but I was able to maneuver the bov out from behind that line and get my spring installed.
Impressions: the seeing does seem to help get the car moving smoother from a standstill. I don't necessarily feel anymore power, I just feel like the car doesn't try to fall on it's face anymore. I took just a short drive. So we will see how it works over the next few days.
Old Jul 16, 2012 | 06:53 PM
  #35
JohnJohn's Avatar
JohnJohn
Got mine done too. Yeah the R60 may give some less skilled wrenchers a fun time. I consider myself skilled at about a 3.5 out of 5 when it comes to "take this off and put this back on". This wasn't THAT easy on the R60.
I would say there is a huge improvement in driving my 6 speed. Mostly when the air conditioner is on. However I did notice some improvements all around.
I think it will had miles to my clutch. I came from and 6 speed R55 S, and this set-up now feels very close to that. When I first got the R60 I stalled it 5 or 6 times before "re-learning" the clutch. Which was basically ride the crap out of it. I felt like a teenager learning to drive a clutch again. This mod solved one of my hang-ups with my R60.
Thanks for posting about it.
Old Jul 16, 2012 | 07:36 PM
  #36
eenunez1's Avatar
eenunez1
I received mine today, thanks for the install tips those that have gone before...
Old Jul 16, 2012 | 08:22 PM
  #37
chrunck's Avatar
chrunck
I highly recommend the NM torque arm insert for helping with clutch feel. It's probably the best value mod I've done so far.
Old Jul 16, 2012 | 08:29 PM
  #38
JohnJohn's Avatar
JohnJohn
I'll be calling Jerry @nm tomorrow...need that from him now, along with exhaust.
Old Jul 16, 2012 | 10:37 PM
  #39
kconner5's Avatar
kconner5
Finally!! I just finished install after 7 hours... It's all due to the annoying part of taking those three allen screws out with the wrong tools, there weren't any hardware stores open at 1:30 am
Took Kowalski for a test drive and he feels better than normal, with the bogging from the A/C gone!
This was a cheap mod but if you don't have the correct tools like me it can be a very long and painful one... But overall worth it.
Thanks to everyone who helped me in this process, I couldn't have done it without y'all!
Kyle
Old Jul 17, 2012 | 10:43 PM
  #40
52804x4's Avatar
52804x4
Grrrr. . .still haven't gotten mine!! Maybe it came in the mail today. . .
Old Jul 18, 2012 | 12:33 AM
  #41
52804x4's Avatar
52804x4
Well, mine did come in today. It's just too bad I can't use it!!!! It is smashed to he**!!
Old Jul 20, 2012 | 02:41 PM
  #42
Bmtespar's Avatar
Bmtespar
So after a few days of driving Pierce with the new spring I have to say I really impressed. The car is sooo much easier to putt around in. I find myself not having to concentrate as much when leavIng stoplights with the new spring. I have been driving manual cars every since I was 11 and have always har an issue with the take offs on the car. This makes it a load easier! I stick by my statement of saying I really don't notice more power, but I certainly notice how much easier the car takes off from a standstill. I highly recommend the $15 spring. Most bang for the buck I have spent on a mod. Replacing my run flats hold a strong second place.
Old Jul 21, 2012 | 10:33 AM
  #43
xenor's Avatar
xenor
Does anyone have an idea of what peak boost pressures we see in the Countryman S? I ask because the diverter valve (is it really a BOV?) is of a diaphragm design which I would question. I'd be interested in peak pressures, or logs of the pressure building and waste gate actuation before/after spring installation.
Old Jul 21, 2012 | 09:55 PM
  #44
advantyper's Avatar
advantyper
Just ordered, can't wait to install
Old Jul 22, 2012 | 06:42 PM
  #45
chrunck's Avatar
chrunck
I did mine today, and it was a real pain in the butt. I wouldn't say that the spring is stiffer, so much as it is longer (that's what she said). I didn't really notice any difference in my quick run around the block, but I'll give it a few days. I haven't driven the car all day, and it's probably more noticeable after significant heat-soak.
Tip for anyone attempting it in the future: a 5mm ball-end allen wrench is your friend. Getting a normal allen wrench in there is next to impossible.
Old Jul 28, 2012 | 02:01 PM
  #46
advantyper's Avatar
advantyper
Do I have to remove/ unbolt the whole intake hose? There r so many wires and hose connected to the main hose
Anyone with DIY pic?
Tks
Old Jul 28, 2012 | 04:59 PM
  #47
Bmtespar's Avatar
Bmtespar
You can disconnect the main air tube from the turbo and the airbox. You can set it to the side without removing all the other attachments.
Old Jul 28, 2012 | 09:29 PM
  #48
chrunck's Avatar
chrunck
After a week with it installed, I can't say I really notice a difference.
Old Jul 30, 2012 | 01:17 PM
  #49
52804x4's Avatar
52804x4
I received my second spring (in perfect shape this time) and put it in this AM. I can't say I notice all that much difference! The only thing that seemed a little different was after shifting there seemed to be more power as soon as I stepped back on the go pedal.
Old Jul 30, 2012 | 01:38 PM
  #50
xenor's Avatar
xenor
I'm noticing some mixed results with this "upgraded spring". I can only imagine that the weak spot in this dv design is the diaphragm rather than the spring's holding power. VW went to a piston style DV in 2009 on their 2.0 turbo.
I wonder if BMW groupe will do the same.
