R59 Let the Mod's begin
Old Apr 7, 2014 | 09:13 AM
  #151
Gil-galad's Avatar
Gil-galad
Originally Posted by Grizld700
I also installed my H-Sport RSB and Michelin PSS's this weekend!
...Gil-galad in your shot of the suspension I see some clear plastic around the springs. Did these come with the Alpha springs, or did you add this yourself? Its a good idea either way considering our winters here (assuming you're an all season roadster), just curious so I know what to expect next year, when I do the springs and struts. I'm also very envious of the rear control arms. Drool...
That's the way they came out of the box from NM Eng. Quite frankly, I'm not sure what function it's supposed to serve.
Old Apr 7, 2014 | 10:21 AM
  #152
TG.'s Avatar
TG.
It's to avoid unpleasant squeaky sounds. Often when lowering a car they need to use variable coils in the spring design in order to keep the over all spring compression rate the same even though the spring is shorter so the car may carry roughly the same load range. In that process the first few coils are often closer to each other which may create unpleasant sounds. It's a plus they provide those directly on them. I haven't seen that yet! Usually it's a modification people add to their car after they notice squeaky sounds.
Old Apr 7, 2014 | 10:39 AM
  #153
Gil-galad's Avatar
Gil-galad
Thanks for the explanation; I can see now how that might happen. I'm a big fan of eliminating any potential squeaking noise sources.
Old Oct 29, 2014 | 03:56 AM
  #154
Aelwulf's Avatar
Aelwulf
Little late to the party but very nice Roadster! If I ever get a new one (maybe Gen 4 if they go back to looking good) I might look at a JCW one. :D
Thanks for the picture with the CarbonMINI stuff. I've been on the fence about some of their cabin items looking cheesy-ish but those look like they come together well. I like a lot of their products.
The wheel looks awesome! PM sent if you don't mind a couple of questions.
Keep up the good work & good luck with the mod bug!
Old Oct 29, 2014 | 10:24 AM
  #155
hemisedan's Avatar
hemisedan
I haven't thought about a cross brace for my roadster. I find that the handling, and I just have the sport suspension, with an added adjustable rear sway bar, does nicely. As a late VW GTI found out in the mountains of the Black Hills a couple of weeks ago. He bugged me by tail gating me, so I pored on the gas. Soon, he was several hundred yards behind. Olga go a kick out of that. Nothin extreme, just played into the curves.
By the way, we then went into Wyoming (boring) down into the Rockies. Yes, we had the top down. Beautiful!
Old Oct 29, 2014 | 03:52 PM
  #156
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I finally was able to complete installation of my aftermarket steering wheel today (my one big "Christmas present").
Sourced from Nexon Motors -
Old Oct 30, 2014 | 04:29 PM
  #157
LILYisatig3r's Avatar
LILYisatig3r
Dear god, that wheel is so beautiful. I hear angels singing.
Old Oct 31, 2014 | 04:47 AM
  #158
Gil-galad's Avatar
Gil-galad
Yeah, I'm still in love with it.
Gotta say though, I owe my inspiration to Steven and his second custom aftermarket install is pretty hard to top...
https://www.northamericanmotoring.co...ml#post3940191
Old Dec 11, 2014 | 09:49 AM
  #159
whoneyc2's Avatar
whoneyc2
"Stella" - Yes, like the blonde from the Italian Job.
I have blacked out all the chrome except for beltline. DDM Race CAI with Hood Scoop. Forge BOV vent to atmosphere.
Custom made 2.5" catback stainless steel exhaust with vibrant high flow ultra quiet muffler and 3" tips, 4 black magic hella 500 driving lights that I wired into existing switches so I can turn them on two at a time.
Plasti Dipped the Air Brake Ducts red. Stage 1 Manic Tune which increases turbo from 11psi to 20psi at max setting. Craven speed adjustable short shifter. Torque arm insert. Craven speed tow hook on rear bumper with "pull to inflate" sticker. Painted the S side scuttles black.
Thats all!.... for now
Old Dec 12, 2014 | 09:01 AM
  #160
Gil-galad's Avatar
Gil-galad
Wow, you've been busy.
That thing must sound like a beast now.
Old Dec 15, 2014 | 07:52 AM
  #161
whoneyc2's Avatar
whoneyc2
Video of It on the dyno this past Friday:
https://www.facebook.com/video.php?v...type=2&theater
Dyno Run #1 - Blue Line is the old run, before intercooler, and tune. I also had the JB+ Tuner on it, so take about 10-15 bhp off the blue line, and thats what it was really at. Red Line - first run.
Dyno Run #2
Attached Thumbnails Let the Mod's begin-manic-tune-1rst-run_100-setting.jpg   Let the Mod's begin-manic-tune-2nd-run_100-setting.jpg
Old Mar 30, 2015 | 06:36 AM
  #162
Gil-galad's Avatar
Gil-galad
My springtime splurge this year...
Old Mar 30, 2015 | 01:43 PM
  #163
TG.'s Avatar
TG.
I don't know whatI'm looking at... you had the whees already right? Is it the brakes or you already had them and got new tires?
If it's the brakes . . . which I think it is . . . how much?
I've eared that there is no difference between JCW and S with the rear brakes by the way. I don't know if that is true...
Old Mar 30, 2015 | 01:52 PM
  #164
Gil-galad's Avatar
Gil-galad
JCW Brembos on a Justa-Roadster. You're correct about the rears.
Old Mar 30, 2015 | 02:01 PM
  #165
Yep,
Before:
Awesome= JCW BBK. The rear are a larger rotor , better bias with the larger 4 post up front based of what I have seen. I really like mine. Stops on a dime. Did you get the Brake flash / ecu at the MINI dealership after install ?
JCW 4 Piston Sport Brake Kit Retrofit 34110432802
http://www.ecstuning.com/Search/SiteSearch/34110432802/
Old Mar 30, 2015 | 02:09 PM
  #166
hemisedan's Avatar
hemisedan
I finally figured that out too. The JCW brakes that is. Looking at you wheel, so nice and shiny, makes me think that I ought to get my silver wheels out and mount some Summer tires on them. It seems like everyone is going to black wheels and now the standard JCW wheels are looking better. I have to put run flats back on before I turn it in on the end of lease anyway.
Old Mar 31, 2015 | 04:53 AM
  #167
Gil-galad's Avatar
Gil-galad
...Did you get the Brake flash / ecu at the MINI dealership after install ?
Yes; and in fact it was the only curious part of the install. When the reflash process initiated the computer indicated that the update should complete in five days. Fortunately, after a couple of hours the clock updated and suddenly (and thankfully) there was only 30 minutes remaining.
Old Mar 31, 2015 | 07:29 PM
  #168
Miata13's Avatar
Miata13
Originally Posted by -=gRay rAvEn=-
Thanks for the interior photo Gil....I just last week placed the Cocomats order for style 51..the black/red dot mats you have. I think they'll look great on our CR R59....
Old Mar 31, 2015 | 08:25 PM
  #169
KennyR's Avatar
KennyR
+1 on the coco mats. I've had them for 18 months, and IMO, they are one of the easiest ways to change the interior look.
Sent from my iPad using NAMotoring
Old Apr 1, 2015 | 04:55 AM
  #170
Gil-galad's Avatar
Gil-galad
+1
Just drove past the Baltimore VDC this morning...too bad I'm not out here for work next week, or I'd take a pic of your baby coming off the boat.
Old Apr 1, 2015 | 02:06 PM
  #171
hemisedan's Avatar
hemisedan
How are these mats for keeping clean or cleaning. I've used rubber mats for the past few years, the WestherTech covers.
Old Apr 1, 2015 | 02:36 PM
  #172
KennyR's Avatar
KennyR
They're not intended for the kind of mess that a Weathertech liner can handle, but for routine use, they generally don't look as dirty as a Weathertech mat does. The dirt kind of goes between the cocomat fibers, and it cleans up fine with a stiff brush and vacuuming. I've done a quick rinse off with a hose, but wouldn't recommend you let them soak for along time. I would probably use a rubber mat for the winter if you drive where there is a lot of slush/road salt.
Old Apr 1, 2015 | 03:05 PM
  #173
TG.'s Avatar
TG.
Yup, for winter weather the rubber mats are a must imo
It not only helps with the snow, mud, slush, but it collects a lot more easily gravel and piece of rock salt you can easily dump out, one would not want to find its way through the carpet liner of the car
Old Apr 4, 2015 | 01:50 PM
  #174
Miata13's Avatar
Miata13
+1
That would have been awesome Gil ....my ship's expected to arrive in Baltimore 2000 hrs 4/8....I'll try "re-finding it" on www.vesselfinder.com once it nears the East Coast.
Local dealer now has assigned it a stock number and it appears now in their "inventory" albeit it's a sold model to ME
http://www.miniofdesmoines.com/Vehic...-IA/2499545653
Old Apr 6, 2015 | 06:31 AM
  #175
+1
Now that's a MINI community
