R56 How do I change temperature settings?
Old Apr 19, 2007 | 05:31 PM
canchili's Avatar
canchili
I can't get in to the menu area to change from Fahrenheit to Celcius...or make any other changes for that matter. When I push the turn signal button as the manual says, the display goes from SET/INFO to HOME with no other options
Old Apr 19, 2007 | 05:35 PM
Warped1966's Avatar
Warped1966
I could be wrong but...
1: Without your foot on the clutch (so the car WILL NOT start) but with the key in, hit the start/stop button.
2: Press and hold the turn signal button. When SET/INFO appears, tap the button to scroll through the menu. Press and hold to set the option you want using taps rather than press and hold.
Hope this helps!
Old Apr 19, 2007 | 06:48 PM
daffodildeb's Avatar
daffodildeb
Some of those settings require that the engine be running.
Old Apr 19, 2007 | 07:18 PM
kendrick87's Avatar
kendrick87
The instructions are printed in your owner's manual I think.
Old Apr 19, 2007 | 09:43 PM
dwdyer's Avatar
dwdyer
You can also do some things on the radio. Hit Menu, then change to BC, and you're there.
Old Apr 21, 2007 | 10:49 PM
canchili's Avatar
canchili
Thanks WARPED the ignition on without starting procedure was what I wasn't getting from the manual.
Old Apr 22, 2007 | 06:22 AM
Warped1966's Avatar
Warped1966
My pleasure. That's how my MA showed me to do mine.
Kimolaoha
Jul 5, 2023 01:04 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
