R56 Bluetooth cellphones - anyone got a list?
Old Oct 11, 2007 | 11:54 AM
  #26
HB4ME's Avatar
HB4ME
Verizon BT Compatible
I have been been dealing with the BT vs. cell phone war for a week with Verizon, this is what I've learned..
The Treo works (my daughters), the Samsung SCH-u140 works (my husbands), the Samsung a870 is not compatible (mine).
After a polite conversation with the Verizon store manager I upgraded to the LG VX8350 which paired but did not download the address book as the others had.
At this point I'm just relieved it to have the phone calls..
Old Oct 11, 2007 | 12:01 PM
  #27
HB4ME's Avatar
HB4ME
I've been dealing with Verizon for the past week trying to get a phone that works, let me share what I've learned:
The Treo pairs/downloads phone book, the Samsung SCH-u410 pairs/downloads phone book, the LG VX8350 pairs but does not download phone book, and the Samsung a870 is not compatible.
Old Oct 11, 2007 | 12:03 PM
  #28
Coffeeman's Avatar
Coffeeman
Originally Posted by iDriveguy
It is my understanding the Mini BT system is the same as that found in BMW.
I also have a TREO and it works fine but loses the connection often and has limited functionality.
The T637 (and like) while out-dated are the best for optimum compatibility.
Okay sorry to bable.
Cheers,
I thought the same thing, but I have learned that the MINI Bluetooth ULF is totally different than those deployed in BMW's. As an example, my Treo 755p works flawlessly with my X5, but it rendered the MINI's Bluetooth ULF inoperable. The ULF in the MINI had to be replaced, after much delay and head scratching on the part of MINI USA.
Old Oct 11, 2007 | 12:08 PM
  #29
TheOfficeMaven's Avatar
TheOfficeMaven
Are you sure about that??? I've always heard that they were the same (other than branding that is). My guess is that you are just seeing differences between the different versions of the ULF module. I believe that there has been 11 or 12 versions/variants of it since its incarnation.
Old Oct 11, 2007 | 01:42 PM
  #30
mikeyjaro's Avatar
mikeyjaro
where's Birdman???
Old Oct 11, 2007 | 02:08 PM
  #31
andyde's Avatar
andyde
My Palm Treo worked fine, dealer helped me set it up.
Like others have posted here, it is a cool voice activated system but I have not fallen in love with it. I still prefer my own ear bud....
Old Oct 11, 2007 | 04:19 PM
  #32
Coffeeman's Avatar
Coffeeman
Yes, 100% sure. The MINI ULF is basically a dumbed down version of the BMW ULF. This explains why the BMW approved phone list is much larger than the MINI approved phone list.
Old Oct 11, 2007 | 05:14 PM
  #33
TheOfficeMaven
Interesting...
Old Oct 12, 2007 | 02:51 AM
  #34
Krut's Avatar
Krut
Has anyone tried retrofitting the BMW ULF to the MINI harness? I'm assuming they're the same connectors.
Old Oct 16, 2007 | 03:00 PM
  #35
pjo1966's Avatar
pjo1966
I paired my Verizon Treo 700p with my Mini. According to the person on the other end of the call, the sound quality was better than when I use my actual phone. On the negative side, my phone book did not transfer over. I tried pushing it and that didn't work either. I guess I'm going to have to manually enter my primary numbers in there.
Old Oct 17, 2007 | 01:26 PM
  #36
Duffer's Avatar
Duffer
My RAZR V3m works fine except for the voice dialing which has to be programmed separately.
Old Oct 21, 2007 | 06:27 PM
  #37
Minidrivr's Avatar
Minidrivr
Originally Posted by Phil K
Here's the list provided by ask.mini:
-Motorola V600-Sony Ericsson T637-Motorola v505-LG PM-325-Siemens S66-Motorola RAZR V3-Motorola V551-Audiovox PPC-6601-Treo 650
My V551 will not dial out (phone continues to dial but the Mini's Nav says called ended as soon as the dialing is completed).
Calling Ask Mini, they gave me another phone number who only deals with bluetooth troubles. The support people there wouldn't help at all unless the phone is on the list, which they said it wasn't.
It will voice dial any address book entry, even without it setup on the phone, but doesn't do me any good since dialing out doesn't work.
Old Oct 21, 2007 | 07:01 PM
  #38
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
My V3m works flawlessly, I switched from an LG 8600 to the V3m about a month ago so I could use the BMW insert for the RAZR.
Old Oct 22, 2007 | 04:30 AM
  #39
MINImanicMan's Avatar
MINImanicMan
Originally Posted by colea
I would be very surprised and disappointed if *any* Bluetooth phone failed to work with MINI Bluetooth. In order to use the term "Bluetooth" in the first place, the Bluetooth SIG (http://www.bluetooth.com/bluetooth/) requires that devices undergo significant interoperability testing. The Bluetooth profiles are standards, designed specifically to ensure interoperability among devices from different manufacturers.
Standards are made to be broken. MINI's bluetooth is not compatible with all bluetooth cell phones. I replaced my old Verizon motorola (v35?) with an LG that was nice and sleek, great features, etc. While my old motorola worked perfectly with the MINI, I could not get the LG to consistently recognize and sync with the MINI. And, if I was able to, I would get cut off mid-call because the bluetooth sync between the LG and my car would just drop. My MINI service guy had to refer the problem to his BMW counterpart who said that's a typical problem. My carrier is Verizon and the choices for compatible phones (re: "tested" and compatible phones) are few.
Old Oct 22, 2007 | 05:55 AM
  #40
pjo1966's Avatar
pjo1966
IIRC, in order for a phone to fully work with MINI & BMW Bluetooth, it has to have the full Object Push Profile (OPP) in order for the phone book to transfer over properly. Some phones only have partial OPP.
Old Oct 22, 2007 | 07:01 AM
  #41
minicounter's Avatar
minicounter
I have this same problem with my v555 (Motorola). I can answer fine but when the phone dials it will not keep the bluetooth connection. The only solution I have found is to get a new phone. I got a RAZR loaner and it works fine.
Old Oct 22, 2007 | 07:06 AM
  #42
Minidrivr's Avatar
Minidrivr
I just tested my gal's V557 and it works fine. I will probably end up getting a Razr since it also has a cradle available for the armrest.
Old Nov 5, 2007 | 12:47 PM
  #43
ssisno1's Avatar
ssisno1
If you enter some numbers under thew favorite buttons they will appear in the phone book when your phone pairs with the mini. Did you get an adapter so you could plug your 700p into the arm rest?
Old Nov 5, 2007 | 10:57 PM
  #44
pjo1966's Avatar
pjo1966
No. The Treo is being replaced by a Razr. I may get the insert for that.
Old Nov 6, 2007 | 06:25 AM
  #45
The QZ's Avatar
The QZ
Originally Posted by diaemus
Anybody have luck with any sprint phones? I need to get me ad the wife new phones when i get back and pick up our mini. We need to make a definative list in another thread, since Mini cant do it for us.
I have Sprint and my Sanyo Katana works great.
Old Nov 6, 2007 | 01:41 PM
  #46
OrionLTD's Avatar
OrionLTD
I have verizon service with the LG EnV VX9900 (orange). Phone worked right away. It took 2 days but all of a sudden, the address book synced up. Since then, she works fine. We will see how long
Old Nov 6, 2007 | 04:22 PM
  #47
sarafil's Avatar
sarafil
Originally Posted by BritBoy
Neither my Verizon Motorola Razr or Cingular cellphone work with the Mini Bluetooth. Anyone out there have a list of compatible phones?
My Cingular razor worked in my BMW with bluetooth. I have tried my Blackberry Pearl (Cingular/AT&T) in the MINI and it works perfectly, including phone book entries (and I have alot of them).
Old Nov 6, 2007 | 07:16 PM
  #48
jeffm5150's Avatar
jeffm5150
Although my Verizon LG 8700 pairs flawlessly and consistently, the call quality is atrocious. Overwhelming amount of static noise prevents me from being able to clearly hear or be heard during a call. The phone book didn't transfer, but no surprise since it's not on the approved phone list. After using it on a couple of calls, I stopped using it ... much better quality call from the phone directly.
I guess I might want to revisit it. Sounds like some users are able to rely on the system once their phone pairs reliably.
Old Nov 6, 2007 | 08:15 PM
  #49
Minidrivr's Avatar
Minidrivr
The razr I got works fine. Call quality is equal to most any speaker phone. It's plenty loud enough since the stereo's volume controls it. Even though it's on the "list" the software version on the list is not the same as I'm using. As far as I can tell, you can't find that software anymore. Seems like Mini tests phones and then stops, never checking that phone again even as new software comes out for the phone.
Old Nov 7, 2007 | 12:01 AM
  #50
ajabbari's Avatar
ajabbari
Coffeeman, this is a rather odd first post as it relates to such a narrow topic but the subject is of some interest to me since I have a Treo 700p (with the MR which essentially makes it equivalent to a 755p). After reading your posts I'm really hesitant to use my phone in my R56 once it arrives. I've had my fair share of bluetooth issues with the 700p in the past (like all Treo users) and have no problem believing that the crappy bluetooth implementation on this phone could in fact kill off the ULF in the car.
I'm just wondering though, how well informed were the people who told you about the overflow issue with the phonebook corrupting the ULF. Is there any chance that this was just a defective ULF to begin with? What phone are you using with your replacement bluetooth module?
As far as this 700p goes this is the last straw for me and I would gladly run it over with my Mini rather than risk the car's bluetooth module, I'm strongly considering not using the bluetooth for the time being and just getting an iPhone next year. The big issue with the 700p/755p is that it seems that there are very few people using it with the R56's and so I haven't really found any other info on the web one way or the other after long term use. At least with the iPhone I figure that it's on the approved list, and there will be "safety in numbers" as far as support is concerned considering the popularity of the phone.
Filmy
15
Jun 6, 2023 06:27 AM
paul7878
Sep 14, 2015 07:44 AM
Sep 10, 2015 11:55 AM
OutMotoring
Sep 8, 2015 06:27 AM
