R56 Webb Motorsports R56 testing starts!
Old Mar 13, 2007 | 02:40 PM
  #76
dwjj's Avatar
dwjj
http://www.turbobricks.com/resources...uartermiledyno
CORRECTING FOR ALTITUDE
If we were dealing with non-turbo cars, this would be easy and we'd publish a formula. But with pressurized cars, the correction factor for altitude depends on the boost you run.
For instance, Sea Level air pressure is 14.7 psi. If you go to a track in Boise, Idaho (2850 feet above sea level) the air pressure is now around 13.25 psi. That's 90.1% of sea level pressure. If the temperature doesn't change and you have an normally aspirated car, your power output will now be 90.1% of what it used to be, so I'd tell you to correct by multiplying your calculated HP by an extra 10.9% (1/.901, or 1.109).
However, (and this is the beauty of turbo cars!!) Let's say you were running 10 psi of boost in the first place. So at sea level, your car was really getting 24.7 psi (14.7 + 10). Now you leave the wastegate at 10 psi and race at Boise. Your manifold pressure is now 23.25 psi (13.25 + 10). Note that YOUR power isn't down as much.. it's down to 94.1% of what it is at sea level. So you should correct with an extra 6.2% (1/.941, or 1.062).
If you wish to calculate your own correction factor, here is a handy table of elevation (feet above sea level) vs. standard day atmospheric pressure (psi):
http://www.turbomustangs.com/turbotech/main.htm
The high-altitude performance of a turbocharged engine is significantly better. Because of the lower air pressure at high altitudes, the power loss of a naturally aspirated engine is considerable. In contrast, the performance of the turbine improves at altitude as a result of the greater pressure difference between the virtually constant pressure upstream of the turbine and the lower ambient pressure at outlet. The lower air density at the compressor inlet is largely equalized. Hence, the engine has barely any power loss.
So turbo-charged means smaller altitude correction factor.
Old Mar 13, 2007 | 02:58 PM
  #77
C4's Avatar
C4
From Wikipedia
FWIW:
Altitude effects
A Rolls Royce Merlin engine
A supercharger remedies this problem by compressing the air back to sea-level pressures, or even much higher. This inevitably requires some energy to be bled from the engine to drive the supercharger. On the single-stage single-speed supercharged Rolls Royce Merlin engine for instance, the supercharger uses up about 150 horsepower (110 kW). Yet the benefits outweigh the costs, for that 150 hp (110 kW) lost, the engine is delivering 1000 hp (750 kW) when it would otherwise deliver 750 hp (560 kW), a net improvement of 100 hp. And while the supercharged engine delivers as much or more thrust as it did at sea level, the airframe only experiences half the aerodynamic drag due to the low atmospheric pressure at high altitude. For this reason supercharged planes are able to fly much faster at higher altitudes.
A supercharger is only able to supply a limited amount of pressure because the compression increases the air temperature, and the engine is limited in maximum charge-air temperature before engine knock occurs. Intercoolers and aftercoolers are often used to get around this problem. The boost is typically measured at the altitude at which the supercharger can still supply sea level pressure (101 kPa or 1013 mbar) and is referred to as the critical altitude.
[edit] Altitude efficiency
Below the critical altitude the supercharger is capable of delivering too much boost and must therefore be restricted lest the engine be damaged. Unless other measures are taken, this means that at least some of the power driving the supercharger is wasted. Also, due to the denser air at lower altitudes, the supercharger is not operating at its best efficiency, and this can cause an additional load on the engine.
For the early years of the war this was simply how it was, and this led to the seemingly odd fact that many early-war engines actually delivered less power at lower altitudes. This was because the supercharger was still using up power to compress air that was not delivering any power back. As the war progressed two-speed superchargers were introduced using better controllers and, notably, hydraulic clutches, that allowed the boost to be managed over a wide range of altitudes by operating at low rpm down low and at high rpm at higher altitudes. This generally "flattened out" the power below the critical altitude.
Throughout WWII British superchargers generally had higher critical altitudes than their German counterparts and, when combined with the higher octane fuels that the Americans supplied, this allowed far higher boost levels, which meant that British airplane engines were generally able to outperform German ones in most situations.
Old Mar 13, 2007 | 03:22 PM
  #78
MotorMouth's Avatar
MotorMouth
Originally Posted by MotorMouth
Good observations about the turbo still able to produce the same hp at altitude..
now if we could make the turbo think it is at altitude when in fact it is at sea level.....
Originally Posted by C4
Simple, just add wings to your R56 and it will take off...
Originally Posted by c4
FWIW: *snip*
relevancy?
Old Mar 13, 2007 | 03:24 PM
  #79
C4's Avatar
C4
J-O-K-E
Old Mar 13, 2007 | 03:27 PM
  #80
ficcion's Avatar
ficcion
It appears that the take home for our "altitude" cars is a substantial increase in horsepower/torque compared to our handicapped supercharged Mini's. The difference for us is huge, greatly noticed and much welcomed!
The sea level folk won't notice the substantial horsepower difference because there is not one to any great degree. However, the torque number will still come into play at sealevel and one should feel that to some degree.
In the end I think Per's numbers of 174/198 are the most correct if the above posts regarding turbochargers hold true. It would seem that although the SAE correction factor is not correct at altitude we would still need some "minor" correction factor applied at altitude as the turbocharger is not 100% effecient (at least according to the article posted by dwjj above)...but just don't try to take me on the track in your '05-'06 at 5280 ft because your gonna lose.
Old Mar 13, 2007 | 03:39 PM
  #81
C4's Avatar
C4
Where are the dyno graphs?
Old Mar 13, 2007 | 03:40 PM
  #82
C4's Avatar
C4
relevancy?
FWIW. Supercharged engines performance at altitude. Relevant for comparison, don'tcha think?
Old Mar 13, 2007 | 03:44 PM
  #83
MotorMouth's Avatar
MotorMouth
J-O-K-E
I had assumed it was meant to be a joke. It was just so unrelated to the post as to be meaningless.
except that it talks about the supercharger performing better at altitude on an airplane due to not being able to use its boost at sea level.
Old Mar 13, 2007 | 03:51 PM
  #84
goaljnky's Avatar
goaljnky
Yes, I also want to see the dyno charts on the stock car....
Old Mar 13, 2007 | 03:55 PM
  #85
dave's Avatar
dave
pug poo picker-upper
Originally Posted by ficcion
but just don't try to take me on the track in your 2005-2006 at 5280 ft because your gonna lose.
You guys have a track at 5280 again?
Old Mar 13, 2007 | 04:04 PM
  #86
ficcion's Avatar
ficcion
Not yet but there is a 6.2 mile course on the way (end of 2007)!!
Pueblo is the only track since Second Creek closed
Kelly
Old Mar 13, 2007 | 04:52 PM
  #87
Larry Clemens's Avatar
Larry Clemens
209 hp
238 lb/ft
Equals approx. 235 bhp. If you believe Milltek's claims regarding their new exhaust gain of 27 bhp we have a stock R56 + Milltek exhaust producing 262 bhp!!! Holy Sh** - My modded R53 may be a lot better looking than an R56 but you don't get #'s like that on a R53 until you have spent some serious $$$$.
Old Mar 13, 2007 | 04:58 PM
  #88
MotorMouth's Avatar
MotorMouth
Originally Posted by Larry Clemens
209 hp
238 lb/ft
actually Miltek claimed ~202hp and based the hp gain on the factory stated hp... so you'd be losing power if randy's dyno was correct.
Old Mar 13, 2007 | 05:19 PM
  #89
gokartride's Avatar
gokartride
Maybe Randy hit that little black unlabelled button between "Sport Mode" and "DSC?" We don't really know what that is for, do we??
Old Mar 13, 2007 | 05:26 PM
  #90
thlaxx's Avatar
thlaxx
very true very true.....
Old Mar 13, 2007 | 06:51 PM
  #91
lava's Avatar
lava
C4 - your quote from Wikipedia is relevant to aircraft, is not so relvent to Webb's results.
That discussion is about aircraft superchargers that are designed for the altitude where they will operate - much higher than Denver. So much so they had to bleed off boost at lower altitudes. A Mini is designed to perform at near sea level, and the supercharger is always going to suffer a degradation in performance as altitude increases.
A turbo charger basically is going to be able to spin faster in thinner air, hence enabling it to build pressures nearly equal to sea level. The exhaust side of the turbo gets its spin from the exhaust and works against the intake air compressing it. When the intake air is thinner, the exhaust air can spin the turbo faster, and pressure levels approach nearly the same as sea level.
So leaving airplanes by the side, all else being equal (and all else is more or less equal with these two cars) the supercharger will take a hit at altitude and the turbo will not.
Old Mar 13, 2007 | 06:55 PM
  #92
chopperace's Avatar
chopperace
I don't get it. I've lived in Colorado my whole life and I have never heard of a turbo having "more" HP at altitude. Not loosing HP I can understand but more.......
Old Mar 13, 2007 | 07:04 PM
  #93
GRMPer's Avatar
GRMPer
Here is our chart:
Run 1 in 4th gear, no fan, Run 2 in 3rd gear, run 3 in 4th gear w/ fan blowing on front of car.
Old Mar 13, 2007 | 07:13 PM
  #94
inomis's Avatar
inomis
Per, looks like on the 3rd run the overboost did not come on. Did you notice any behavior like that in the autocross? I wonder what the recycle time is for the 30 second overboost period?
Old Mar 13, 2007 | 07:15 PM
  #95
GRMPer's Avatar
GRMPer
I think it's more that the dyno pull is so quick in 3rd gear that boost doesn't have a chance to build completely, the SRT-4 does the same thing.
Old Mar 13, 2007 | 07:25 PM
  #96
inomis's Avatar
inomis
Hard for me to see, the green line is 3rd gear then. I was thinking it was the 3rd run and you used the fan to cool things back down. But it was the 3rd run that gave you the best number. I had 1 out of 3 correct!
Old Mar 13, 2007 | 07:27 PM
  #97
slag1911's Avatar
slag1911
Originally Posted by dave
Rumors continue that MINI is having issues getting beyond 200 HP with the 1.6L and the current turbo. Word is they are strongly considering boring out to 1.8L to get the full JCW kit up to 230 HP.
Munich just needs to use Randy's dyno
Old Mar 13, 2007 | 10:54 PM
  #98
MotorMouth's Avatar
MotorMouth
GRMPer, could you post a larger pic of it?
Old Mar 14, 2007 | 05:13 AM
  #99
C4's Avatar
C4
Still no charts?
Old Mar 14, 2007 | 05:24 AM
  #100
C4's Avatar
C4
I've kind of got to agree with \
  • Rumors continue that MINI is having issues getting beyond 200 HP with the 1.6L and the current turbo. Word is they are strongly considering boring out to 1.8L to get the full JCW kit up to 230 HP.
Interesting because I have read other sources denying these rumors.
