R56 Crankshaft compatibility N18
Old May 26, 2026 | 11:12 AM
Cadmat's Avatar
Cadmat
Hi again,
so can I get any N18 crankshaft and install in my good block? Are there any codes to match?
I would keep my pistons and use the new used crankshaft with its rods. Then I will check what main bearings I need.
thanks
Old May 27, 2026 | 04:49 AM
mkov608's Avatar
mkov608
I would check real OEM dot com and make sure the part number of your crankshaft matches the used one you are attempting to purchase. Then I would take the crank along with the block, pistons etc and have them inspected by a qualified machine shop to make sure all the parts are within specification. Engine assembly is easy, it's the machine work and ensuring the crankshaft journals have the proper surface finish that build long-term reliability.
Also, don't worry about BMW's TIS main bearing color codes; I installed a set of King bearings in my rebuilt N12, and after three oil samples, oil analysis shows a very healthy engine. You'll want .002 - .0025 clearance on the mains.
Lou@Prototype-R
Mar 6, 2026 01:16 AM
pkgmSu2000
Dec 23, 2024 07:34 AM
Robyv83
R59 :: Roadster Talk (2012+)
Jun 1, 2022 10:55 PM
Audiophile_Mark
11
Nov 1, 2012 08:38 AM
