R56 Fan doesn't run after turning car off
Old May 7, 2026 | 02:47 PM
SuperDave010's Avatar
SuperDave010
I've noticed recently that my radiator fan isn't staying on after I turn the car off. I tested it by turning the A/C up to max while sitting, and it does run then, and I haven't had any issues with overheating. I've done some searching, and haven't found anything specifically on this issue - any thoughts?
Old May 7, 2026 | 03:50 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
N18? If so, the DME considers three parameters to run the fan after turning off the engine: (1) coolant temp, (2) high-side refrigerant pressure, (3) turbocharger-related calculations based on length of drive, engine load/boost usage, and exhaust gas temps.
Old May 14, 2026 | 12:38 PM
SuperDave010
Thanks for your reply. Yes, it's an N18. My concern is that it's never staying on after stopping anymore, where it used to nearly every time I'd stop. The only thing that's changed recently is that I put a new clutch in, which I don't think should have any bearing on the issue. I'd suspect a bad sensor somewhere, but I'm not getting any codes, so that seems unlikely. Do you think I should be concerned?
Old May 14, 2026 | 01:04 PM
Maybe, maybe not
Community Builder
Do you live in an area where the weather is hot, mild, or cold? Do you have scan tool that reads live data?
Do this: Start the car and turn the A/C on max cold and max blower. Does the radiator/condenser fan run at high speed under these conditions?
Old May 14, 2026 | 01:13 PM
SuperDave010
Mild - it's mostly around 70/75 all year. I've had the car for about ten years, though, and my driving patterns haven't really changed - I'm noticing that the fan doesn't run at shutoff at times when it would have before.
The fan does come on when I run the A/C on high at idle, so I know it's not a bad fan.
And yes - I do have an OBD dongle that will show live data on my phone. Is there something particular I should be looking for there?
Old May 14, 2026 | 02:22 PM
Maybe, maybe not
Community Builder
Monitor the coolant temperatures from first start of the day to returning home. Do the reported readings seem consistent with expectations?
Do you ever see or hear your fan run on low speed?
Old May 15, 2026 | 08:04 AM
If it turns on when the engine is cold, its the thermostat housing and sensor, or possible air in the top of the thermostat housing from a leak on the transmission.
If it run long after a drive and hot, its normal but only for track days or super hot days, like in the 80-90 degree all day.
Yep, check the readings and see if its going over 219 -225+ degrees after shut down.
PJ Wooter
Mar 12, 2024 05:58 AM
akayededid
Oct 30, 2010 09:08 AM
Soul Coughing
Oct 8, 2010 01:28 PM
soccerbummer1104
Nov 10, 2009 08:37 PM
mariog
Feb 18, 2005 07:52 AM
