R56 R56 - crossover pipe/thermostat - now running rough
Hi all,
I did the crossover/thermostat job, and besides overheating when it failed, the vehicle was running fine. Once reassembled, it now is throwing codes for each cylinder. I cleaned out the plugs, made sure everything was plugged in correctly....in fact, I removed and reinstalled everything right down to the intake manifold.
Symptoms are that it runs rough, accelerator will make the rpms rev really high once and then it dies off. Cannot maintain idle, stops with any fuel given.
Any suggestions?
Thanks in advance.
Any suggestions?
Thanks in advance.
What year R56? N12, N14, N16, or N18?
How badly did the engine overheat?
For downstream O2 sensor code P0137, check whether the connector may be contaminated with coolant or whether you potentially swapped the O2 sensor connector with another sensor connector.
It's a 2008 n12 non-turbo. I pulled off and headed towed when it started to overheat, so not too badly.
My thoughts yesterday as well were that maybe I swapped a couple of sensors, but I'm not sure which sensors would actually be able to be interchangeable?
I'll check the o2 sensor connector, thanks
guruerror
Dec 13, 2019 04:53 AM
