R56 Oil leak onto exhaust pipe
Old Jan 11, 2026 | 01:58 PM
stinkbug's Avatar
stinkbug
Have a 2010 S with the 6 speed manual.
70K miles,
have an oil leak thats dripping onto the exhaust pipe , right where the pipe bends from vertical to horizontal and goes under the transaxle.
it appears to be coming from right above the left front corner of the oil pan, behind the heat shield for the cat, of course I cant see up in there,
we washed off everything and put UV dye in the oil, and this seems to be one of the places its coming from,
its also leaking from where the clutch cylinder bolts on and from the weep holes in the bottom of the bellhousing., but those dont drip onto the exhaust
pipe and stink.
whats up behind the cat heat shield that would be leaking?
is this symptoms of the oil filter housing gasket?
Old Jan 11, 2026 | 05:15 PM
cristo's Avatar
cristo
Alliance Member
Mine was the oil filter/cooler
housing gaskets (2009 JCW R55).
another likely suspect would be
the turbo oil line. Same teardown
to do either so if you do one of
these, you ought to do the other
at the same time.
Old Jan 12, 2026 | 07:51 AM
Raymo2u's Avatar
Raymo2u
I will agree, its most likely the Oil Cooler or the Turbo feed or drain lines. I would get a borescope and look closer, you could always drop the downpipe to get a much better look.
Old Jan 12, 2026 | 12:22 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
We sell this great kit that has everything you would need to do the job. we recommend the oil cooler seals as well, but is optional. https://detroittuned.com/detroit-tun...arch_query=tol
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
BigDog9721
Nov 13, 2023 12:32 PM
TG.
Apr 20, 2022 08:03 AM
gervaisj
Jun 20, 2010 05:40 PM
ggv
Apr 17, 2008 10:28 AM
