All, ,this is a picture of my '10 Mini-S front end with a small leak... 1st picture is a picture of the whole front end.... 2nd picture is specifically where the leak is... is this a heat exchanger pipe leak? is this something that is an easy fix? looks to me like if i can get down there, I could tighten the pipe to stop the leak... and it's a very small leak, it just smells alittle to be aware of... thoughts? Thanks in advance!
Its easy from the bottom and then on the top nut, not too bad. Easier to get to the aux water pump from the side or bottom near the oil filter housing.
