R56 Swap heater control with thermostat in degrees with one without?
Old Nov 27, 2024 | 01:14 PM
Lipofskyphoto's Avatar
Lipofskyphoto
Can I simply swap the center console with a heater control with the thermostat in degrees with the heater control without the Degree setting?
Do I need to install as sensor as well? Is the wiring there?
Thanks!
Old Nov 30, 2024 | 08:04 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Are you asking if you can retrofit the automatic climate control into a car with the manual controls? There is a bit more to it than just swapping the control console. You’ll have to change the blower motor, control resistor, and add the solar sensor on top of the dash, and add a wiring harness. The whole dash will need to come out for the retrofit. It’s not an easy swap, but it can be done.
hooverr77
Aug 23, 2020 09:15 AM
njaremka
Aug 12, 2020 06:09 AM
nwflyingdutchman
R60/R61 Stock Problems/Issues
Dec 7, 2017 12:52 AM
scarabbrian
Nov 26, 2016 07:35 AM
scott48
Sep 10, 2010 11:16 PM
