R56 JCW Some tests with Data logging
Dear all,
Sorry if this as been discuss before, but I would like to have your opinion on this.
Today I did some road tests with my mini copper 2009 JCW with 180.000kms on the clock and stock engine and from data logging in WOT I got:
- Throttle actuator: 90%
- MAP: 28.7 PSI
- "Calculated boost" ( from the Car Scanner pro): 1.05 Bar
- MAF: 154.11 g/sec
- Fuel rail pressure: 12.410 kpa
Regarding this data, is it normal for a stock engine or is it under what should be expected?
best whishes and happy new year
Cassa
- MAP: 28.7 PSI
- MAF: 154.11 g/sec
Cassa
Sounds about right to me... What is your altitude? MAP and boost pressure are about the same, assuming an altitude of ~2500 ft.
Is there a reason you think your car isn't performing as it should? 180,000 kms is enough to see a performance degradation....
My altitude is sea level Bar pressure today is 1021hPa
No particularly reason but I'm planning to do a Stage1 and once of the things that caught my attention is I cant get 100% throttle actuator during WOT. However, if the car is not running and I press until the end the accelerator pedal, I can see it at 100%.
This happens also with you?
I don't have an N14, so my throttle mapping might look different from yours. I do know that these cars use an "Engine Load" calculation to determine throttle and boost pressure targets.
Do you have a tuner that you're working with yet? Reach out to @Lou@Prototype-R . He has built a massively deep N14 database of knowledge. He might even be able to help you with some pre-tune data logging to determine the health of your engine.
