R56 Limp mode after cleaning intake and TB
Old Aug 15, 2023 | 10:20 AM
yvatyan's Avatar
yvatyan
Hi guys,
Recently I did some work on my Mini Cooper S 2008, took off the intake manifold and cleaned throttle body. Then, after I assembled it, I began to get following errors just after I start the engine.
002B32: DME: Throttle-valve actuator, control range
002B31: DME: Throttle-valve actuator, control range
002B1E: DME: Throttle-valve actuator, activation
002B2B: DME: Throttle-valve actuator, position monitoring
002B1D: DME: Throttle-valve actuator, activation
002B43: DME: Throttle actuator
I thought the TB can be faulty but when I look at live data at Carly the following scenarios are occurring.
1. When I play with acceleration pedal I see with pedal press, changes the pedal %, TB target %, TB low stop % and TB current % values. But when I leave pedal in some position (either it is in mid way or pedal to the floor), TB values reset back to 9% after reaching (or it seems so) that position, and remain there regardless I press the pedal or not. And at this moment I get engine malfunction and cruise mode error on Mini's computer.
2. Sometimes I manage to get the pedal to 100% that doesn't cause TB reset to 9%. In that case target value is 100% and actual value and the lower stop are somewhere near 98%.
3. When I listen to TB working with my ear near intake manifold, there are no scratching noises just DC motor working.
I've tried to disconnect the battery, to do adaptation procedure that I found in the internet (ignition on, pedal to the floor for 90 sec, off position, pedal release) both while TB is open like in scenario 2 and TB in default 9% and it does not work.
Also, in case of key fobs, as I understand, the key positions are the following
ignition on - means put the fob in place and press start button without depressing the clutch.
off - means take the key fob.
Any ideas, what can I do next or probably I've done the TBA wrong.
Thank you for reading this and your help.
Old Aug 15, 2023 | 12:56 PM
Gln0238's Avatar
Gln0238
This is probably too simple but I’ll share it just in case.
Double check the intake tube clamp my 2007 works it way off a couple times a year. I have learned to push it back on and retighten before it comes off enough to put it in limp mode. Good Luck
Old Aug 20, 2023 | 02:58 PM
texasmontego's Avatar
texasmontego
Did you confirm everything is plugged in? There is 3 plugs under the intake manifold, TB, boost solenoid, and fuel tank breather valve. Did you confirm these are plugged in?
Old Aug 21, 2023 | 10:36 AM
Thats what i was guessing. Something is switched or not plug in.
Old Aug 26, 2023 | 05:57 AM
texasmontego
Early in Mini building I swapped the thermostat plug with another (forget now) and it acted all kinds of weird. With enough force, every plug will fit. haha
Old Oct 4, 2023 | 08:11 AM
fix's Avatar
fix
Originally Posted by yvatyan
Hi guys,
Hi , I did the same and I got the same issue, did you fix it?
thanks buddy
Ju1cE
Jul 5, 2021 08:33 AM
wertslj
Apr 23, 2020 01:40 PM
tonymtorres47@hotmail.com
Sep 3, 2016 06:52 AM
gen3usa
Mar 30, 2009 10:21 AM
Razputin
Nov 24, 2003 04:29 PM
