R56 BOV Connector struggle NEED HELP
Old Aug 12, 2023 | 08:08 PM
CakeEater's Avatar
CakeEater
Hi Yall, I have a 2013 MCS. It has had a turbosmart dual port BOV installed for quite some time, and I am in the process of switch to the Turbosmart plumb back recirc valve and I have an issue.
The dualport that I am removing had no connector plugged into it, and i cannot find the right connector to plug in to the new BOV.
For your info, it was a previous iteration of their dual port valve that tapped into the vacuum system on top of the intake with a tap and tube running to the BOV.
I am seeing 2 dummy plug right near there that look to be PCV heater hoses, but where is the plug that goes into the BOV?
I have the M7 silicone intake boot hence the need for PCV heater delete..
I need to find the plug for the BOV that would plug into this:
And all i can currently find are what look like these pcv heater connectors which look like this:
HELP!
Old Aug 13, 2023 | 04:21 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If I remember correctly, the diverter valve connector is down low, below where the diverter valve sits, and the connector comes up to the valve
Old Aug 13, 2023 | 05:59 AM
CakeEater's Avatar
CakeEater
You rock, just went and looked under, probs the only place i didnt look yesterday, and i found it.
zachsa
Aug 9, 2014 10:04 PM
NiX26
Jun 5, 2013 02:33 PM
Minicoopr50
Dec 7, 2012 01:14 PM
Thruxton
Nov 30, 2011 02:55 PM
