R56 2009 - Passenger floorboard is wet
2009 Cooper S
117,000 miles
Sunroof
I have already worked on the sunroof drain lines, drain to just behind the front wheels.
The forward part of the passenger footwell area is wet.
Where else is water known to come in from?
Thank you.
117,000 miles
Sunroof
Thank you.
Front door seal on the side. Also its rare but it could get there if it goes up in the HVAC system from a window cowl that was damaged or removed.
Front door seal or the window glass needs adjusted. https://www.northamericanmotoring.co...-b-pillar.html
Window cowl
https://www.northamericanmotoring.co...need-help.html
Window cowl
I part of the seal on the passenger side was not attached to the cowl, along with a missing battery cover.
Yea, under heavy rain people did not have that battery cover on and it got into where the cabin filter is and dripped on the floor.
happier
Nov 21, 2012 12:00 PM
