R56 Car shaking and sputtering
Old Nov 21, 2022 | 07:12 PM
MiniCoopa0_0's Avatar
MiniCoopa0_0
So I was on my way home, went to accelerate and bam… mini takes a dump. Car is sputtering and sounds like a little helicopter. You can hear it out of the exhaust… like poo poo poo poo poo poo and it only gets worse as I accelerate. The entire engine is shaking now.
I’ve had a check engine light that leaves and comes back (P054B camshaft position sensor cold-start retarded bank 1) and have yet to install a new VANOS solenoid.
I also haven’t upgraded or changed my coil packs in 85,000 miles. And I’ve modded it. I don’t even know where to start someone please help.
Old Nov 21, 2022 | 08:38 PM
CakeEater's Avatar
CakeEater
I mean if P054B means u need a new vanos solenoid i would get that first, then new plugs and coils and clear codes and restart.
Old Nov 22, 2022 | 03:33 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Skip the coils and plugs for now, but replace that vanos solenoid immediately
Old Nov 22, 2022 | 04:42 AM
MiniCoopa0_0
gotcha I’ll do that tonight. What can that cause if it fails?
Old Nov 22, 2022 | 04:43 AM
MiniCoopa0_0
Timing chain
Also, what are the signs of a bad timing chain? Eek
Old Nov 22, 2022 | 05:43 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
From your other posts, you have a 2013 R56? I would worry less about the timing chain.
If the vanos solenoid goes out, the cam will not be in the correct position, which will cause stumbling and drivability issues, especially on the N18, which uses vanos to control the intake phasing instead of a throttle plate.
The N18 has two vanos solenoids: intake and exhaust. I would replace them both as cheap insurance / maintenance. Replace both solenoids, clear the codes, see if that helps or brings up more codes, and go from there.
Old Nov 22, 2022 | 08:51 AM
MiniCoopa0_0
Vanos
Damn thanks for all the info it’s a big help. I really hope I didn’t mess anything up by not replacing it earlier. I’ll replace both and let you know how it goes
Old Dec 1, 2022 | 12:59 PM
MiniCoopa0_0
Help again
So I replaced the exhaust VANOS solenoid I had, And replaced the coils. Stumbling and misfiring went away. Cleared the codes I had last night. But this morning I got the code P054B (Exhaust Timing over retarded bank 1).I also have an engine malfunction light on. What do you think now?
Old Dec 5, 2022 | 05:10 AM
Mini242's Avatar
Mini242
mine did that then my timing chain failed
Old Dec 5, 2022 | 07:53 AM
bagwell's Avatar
bagwell
I don't know about cheap....OEM part is showing $207 at ECS. Is aftermarket ok for this part?
Old Dec 5, 2022 | 09:17 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I used these from RockAuto:
https://www.rockauto.com/en/moreinfo...t=12910&jsn=14
Purchased in March 2019, still going strong.
Old Dec 7, 2022 | 12:06 PM
MiniCoopa0_0
Timing chain
What kind of problems were u having with the car? Any specific noises?
actasci
Jun 15, 2023 08:36 PM
Russter500
Mar 22, 2017 05:45 AM
dkamp
R55 :: Clubman Talk (2008+)
May 12, 2014 06:12 PM
mr.lussier
Mar 22, 2013 09:28 AM
DustinDallas
May 17, 2006 07:08 AM
