R56 Installed catch can now car misfires
Old Nov 14, 2022 | 09:58 AM
Stingreh's Avatar
Stingreh
I am assuming I messed up when I installed my passenger side catch can this weekend... Car was running fine other than an "unmetered Air" code which is one of the reasons I installed the passenger side catch can. Now under medium to heavy acceleration the car starts misfiring bad. The code is misfire on cylinder 4 and misfire on all cylinders. When it first happened I pulled over and the car was running on 3 cylinders with number 4 not firing at all. I swapped coils and 4 was still not firing. I cut the car off and when I restarted it, all cylinders were running... I went and drove it again and the same thing happened again so I cut the car off then started again and all cylinders firing. I went back to the house and took the catch can off and put the plastic pipe back on that runs from the valve cover to the intake manifold. I went and drove the car again and same thing happened but this time I cleared the codes with my scanner while car was running and the 4th cylinder started firing again. Not sure if I could have messed up a wire or injector when I was snaking the pipe through the manifold or what. Everything looks to be connected and I don't see any broken wires but it is tough to see much under the manifold. Any Ideas?
Old Nov 16, 2022 | 03:23 PM
oldbrokenwind's Avatar
oldbrokenwind
Your "unmetered air" could be caused by an OCC drain (valve or hole) being left open, and the manifold is getting air through it. Shouldn't cause a misfire tho --- can't help with that one. Try resetting the ECU in addition to clearing codes.
Old Nov 18, 2022 | 07:21 AM
joseph.pokorski@gmail.com's Avatar
Consider getting your intake walnut blasted. Cleared up my misfires and the renewed power feels great. 3 hours labor at your dealer.
J Free
Sep 23, 2017 09:49 AM
ShadyCoop
Sep 20, 2015 08:57 AM
InjectedGT
Feb 24, 2015 11:42 AM
dchaney
Dec 29, 2014 09:43 AM
ms.mini
Mar 31, 2014 06:36 AM
