R56 Battery Issue on 2011-R56 MCS
Old Nov 7, 2022 | 11:15 AM
ipsimo's Avatar
ipsimo
new to forum and looking to understand what is causing the battery issue i'm having with my 2011 R56 MCS
battery is relatively new in milage terms (no more than 5k miles) but about 4-years old now
issue: battery randomly dies after parking car - gear shifted into P, press start/stop button to turn off car then everything dies; entire dashboard is off, and key fob is stuck in key hole
i've been able to resolve the issue by popping open the hood and using a jumper cable clamp i touch the black negative terminal and everything starts up again
i'm using the car every couple of days (for short trips) and there doesn't seem to be any particular pattern as to when it happens - it didn't happen for a month and then 3-times in 2 days.
do i have a battery issue or is it something to do with the fob?
Old Nov 7, 2022 | 11:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Could be a battery issue. Battery age is more relevant than mileage. Also, with short trips and limited usage, the battery isn't really getting a full charge.
Old Nov 7, 2022 | 09:44 PM
giorgos's Avatar
giorgos
I agree with njaremka but your choice of wording inserts some doubt:
Please elaborate on:
- "using a jumper cable clamp i touch the black negative terminal" (just one clamp??)
Is connecting only one of the two wires enough or are you actually fully connecting your car using both wires of the jumper cable to a donor voltage source?
Old Nov 8, 2022 | 02:08 AM
Vanski's Avatar
Vanski
@ipsimo
Does your battery have an IBS(intelligent battery system)? It’s that square looking thing on your negative cable like the photo below. If so, then you you’ll need to register your battery with your scan tool.
kongjie
Oct 17, 2017 09:15 AM
Tsmith
Mar 11, 2013 08:36 PM
ImagoX
Jul 10, 2011 02:07 PM
The QZ
Sep 4, 2010 11:04 AM
Mini_Chan
Apr 4, 2010 06:50 PM
