R56 Mini Roof Rack Clamping Plates not moving
Old Oct 12, 2022 | 05:29 PM
maxiPool's Avatar
maxiPool
Hello, I recently bought a second hand roof rack; the rear bar seems fine, I can open and close the clamping plates by hand.
However, the front bar's clamping plates are not moving at all by hand. They won't budge and they stay in the open position.
OPEN position: Mini Roof Rack Clamping Plates not moving-128sa05.png
I would like to be able to move them into the closed position which will be necessary when mounting them on the car.
CLOSED position: Mini Roof Rack Clamping Plates not moving-t96lnfs.png
Finally, is there a proper way to loosen the clamping plates mechanism so that I can move them by hand without breaking anything?
Old Oct 13, 2022 | 03:50 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Those are spring loaded, and the spring is pretty stiff. Did you get the tool set, too?
This video is pretty good for showing the installation procedure:
Old Oct 13, 2022 | 04:48 AM
maxiPool's Avatar
maxiPool
I have the lever to press in the clamping plates and the dynamometer key.
I can install the rear bar with no issue since the clamping plates on that rear bar can be moved from open to closed position by hand.
However the front bar's clamping plates seem stuck.
I'm asking for a way to unstuck them.
If you know how to, please let me know.
Old Oct 15, 2022 | 12:46 PM
maxiPool's Avatar
maxiPool
The clamps mechanism was rusted enough to seize.
I drowned it in WD-40, let it sit for 15 minutes then I grabbed each plate with a 1 foot vice-grip and after a couple tries it finally became loose again.
cricky
May 22, 2011 08:45 AM
slindo
Jul 18, 2009 12:16 PM
roaduscarnivorous
Apr 2, 2008 08:54 PM
