R56 Transmission
Old May 18, 2021 | 10:24 PM
Jimbo924's Avatar
Jimbo924
Transmission
Hey guys I’m new here I purchased a 2007 Mini Cooper s having an issue with the manual transmission goes in gear but will not move bought car from a buddy after he treated it like crap hit a curb and tore the bumper cover off but car will not move any idea where to start to diagnose the problem
Old May 19, 2021 | 03:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Usually if you are 100% sure the transmission is in gear and the car won’t move, the clutch is done or one of the axels has popped out of the differential. I would get the front of the car in the air and crawl underneath to see if anything is visibly out of whack.
Old May 19, 2021 | 12:17 PM
Jimbo924's Avatar
Jimbo924
Thanks will do
Old May 21, 2021 | 08:02 AM
keduMINI's Avatar
keduMINI
Let us know what you find out. Thanks.
Also, check the hydraulic line/piston attached to the transmission housing (driver's side near front of vehicle at bottom of the bell housing). This assembly compresses the clutch fork as you press the clutch pedal.
Can you smoothly engage the gear shifter into each gear, including reverse, when the clutch pedal is depressed?
Noahl
Oct 8, 2018 11:18 AM
mini419
Mar 3, 2014 06:43 AM
kellyscooper
Aug 3, 2012 10:42 AM
waltph
Aug 30, 2007 01:29 PM
