R56 Radiator Fan Issues
Old May 14, 2021 | 10:48 AM
MINI8's Avatar
MINI8
Radiator Fan Issues
Guys,
Yesterday, after driving over 400 miles with the AC on and shutting my '07 Cooper S once in my garage, I noticed that the radiator fan did not kick in, the way it usually does. I decided to disconnect the battery, and once reconnected, the fan kicked in.
What could it be?
Your input will be greatly appreciated!
Regards
Old May 14, 2021 | 12:04 PM
oldbrokenwind's Avatar
oldbrokenwind
Here's a breakdown of the engine cooling system, copied from an old TIS document. Check out the system functions, near the end of the document.
I gave up long ago, trying to figure out when the fan should be on or off. Adding an external coolant temp gauge might help.
File Type: pdf
Old May 15, 2021 | 02:45 AM
Vanski's Avatar
Vanski
Wow, that is great info Old Broken Wind.....Thank you for the PDF link.
Old May 16, 2021 | 12:26 PM
MINI8's Avatar
MINI8
Thank you oldbrokenwind!
Aaron Leong
Factory JCW Talk (2009+)
Jun 5, 2018 04:44 PM
Euanmclaughlan
Oct 19, 2017 11:21 AM
akayededid
Oct 30, 2010 09:08 AM
minibeel
Sep 10, 2007 06:31 PM
