R56 Cylinder #4 misfire solved
Old Mar 22, 2021 | 02:46 PM
mkov608's Avatar
mkov608
Anybody out there experienced burn-through on their exhaust valves?
Car: 2012 Justa (N16)
Owner states:
Only premium top-tier fuel
Never overheated
Leakdown test showed 95% leakdown in cylinder 4, and adding oil to the cylinder didn't reduce the reading; at first I thought it had dropped a valve seat, but the valves were not stuck open and they were moving normally when I turned the engine over manually. I used a borescope in the exhaust port to find the problem.
Old Mar 22, 2021 | 06:45 PM
Yoshimura 1's Avatar
Yoshimura 1
That's great that you found the culprit.
Old Mar 24, 2021 | 04:49 AM
Yoshimura 1
I had that happened on two different heads it's pretty much a known issue.
Old Mar 24, 2021 | 03:05 PM
mkov608's Avatar
mkov608
Known to whom? This was a first for me. Did you find out what caused it on your valves?
Old Mar 24, 2021 | 06:01 PM
Yoshimura 1
When I went to the machinist he said it's a very common issue for this to happen. When I
purchased the vehicle it wasn't running the compression was vey suspect on #3 cylinder.
After taking up the head I decided to get it checked out and the valve replaced. The previous owners
did absolutely nothing to this vehicle Maintenance wise.
Old Mar 24, 2021 | 06:06 PM
Yoshimura 1
My partner just bought a clean 2008 mini cooper clubman s with 49,000 original miles this exceptionally clean car
had a burnt exhaust valve. We was looking to see if the gasket was blown everything was intact. So this one is also in
the shop getting checked out.
Jerry Balch
Aug 29, 2022 03:53 PM
Da_Ghost
Jun 21, 2020 02:08 PM
mjcari
Jun 12, 2016 07:03 AM
Jesperss
May 2, 2013 06:58 AM
nethack
28
Apr 26, 2013 01:52 PM
