R56 Valve Seat Issues
Old Mar 20, 2021 | 08:49 AM
mkov608's Avatar
mkov608
Valve Seat Issues
I've seen a technical bulletin on the internet about 2007-2010 (N12) engine valve seats dropping out of the cylinder head, and it happened to my 2007. Does the N16 Engine have the same problem? I pulled up the valve seat part number, and they are identical between the N12 and N16 engines.
http://www.engineprofessional.com/TB/TB113017-1.pdf
I've picked up a 2012 Justa recently, and one of the exhaust valves in the #4 cylinder has a hole in it, so I'm wondering if I should replace all the valve seats with the deeper valve seats while I have the head in the shop.
Mark
Old Mar 21, 2021 | 08:14 AM
thefarside's Avatar
thefarside
Replacing all seats would be my choice.
Replace all exhaust valves as well. Unless there is significant stem wear, the intakes should be fine to re-use.
Old Mar 21, 2021 | 08:19 AM
mkov608's Avatar
mkov608
Do you have a good vendor for the deeper valve seats? Thanks in advance!
ssashton
Apr 2, 2021 03:35 PM
Digitys
Nov 30, 2019 03:54 PM
outlawspeeder
Aug 2, 2019 11:36 AM
htroberts
Nov 9, 2015 08:31 PM
shanksamillion
Mar 11, 2015 08:41 PM
