R56 P045B code
Old Mar 15, 2021 | 04:11 PM
LDAWG48's Avatar
LDAWG48
P045B code
I have a 2011 mcs and it’s throwing a P045B code and the cold start is a little louder than normal but that’s the only real difference I can tell. I’ve replaced both the camshaft and crankshaft positioning sensors and the problem went away for about a month and now it’s back. Does anybody have any input on what this might be?
Old Mar 15, 2021 | 04:21 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
What about your VANOS solenoids? Also, how many miles on your timing chain?
Old Mar 15, 2021 | 04:26 PM
LDAWG48's Avatar
LDAWG48
haven’t checked the solenoids but I will be tomorrow. Timing chain has almost 85k on it. It’s the one that came on the car as far as I know. I also have a bigger intercooler, catless dp, Invidia exhaust, colder plugs and a stage 2 RPM tune. Idk if that would have anything to do with it
Old Mar 15, 2021 | 04:38 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I’m curious, because the P045B code is the general OBD code for exhaust gas recirculating fault. That would make me think cam timing related on the N18 engine, but I don’t know for sure.
Since you’re running an aftermarket tune, might want to invest into a BMW/Mini scanner to check for DTCs, which are not picked up by the generic OBD scanners. I’m sure there are other codes in there to tell you what’s going on.
uptickman
Apr 10, 2021 10:31 AM
Thatsunsetboy
Sep 23, 2020 11:47 AM
raybo1
Feb 26, 2019 07:48 PM
Andrew Park
Feb 13, 2019 08:43 PM
Matt_Tate
Oct 22, 2012 12:26 PM
