R56 Coolant Leak
Old Mar 11, 2021 | 08:41 PM
Sassenach's Avatar
Sassenach
Coolant Leak
I have a coolant leak from what I thought was the expansion tank. Replaced it. Topped up fluid and left car idling for 15 mins. Expansion tank went up and down. No leaks. Took for a test drive for a few miles. Coolant dripping again from under the turbo area. Any ideas?
Old Mar 11, 2021 | 11:01 PM
Staxtis's Avatar
Staxtis
The expansion tank hardly fails.....Actually all the other fails easier.
Could be radiator of the AC could be tyour coolerSome hose...Coolants are easy to find out where its leaking most of the times..!
Old Mar 12, 2021 | 02:50 AM
knt's Avatar
knt
Simplest would be
If that fails then pressure test the system, also on YouTube.
Old Mar 12, 2021 | 08:46 AM
Sassenach's Avatar
Sassenach
Thanks, the UV kit looks pretty cool. It's just odd it did not leak for the 15 mins it was idling.
Old Mar 12, 2021 | 02:42 PM
RicksterR56's Avatar
RicksterR56
Could be a coolant leak where the coolant connects to the Turbo. I don't think its under pressure until you're moving and using the turbo. At idle you would not get a leak. The turbo has in/out coolant and oil lines that cool and lubricate it. These connections do fail!!!
Good Luck,
Rick
Old Mar 12, 2021 | 06:17 PM
mellocooper's Avatar
mellocooper
Yes I recently had a crack in the T where the return line from the turbo joins in, that’s a bit of a common failure I think. That and of course the thermostat.
Jimmy Chiu
Jan 4, 2020 12:12 PM
fatbysl
16
May 16, 2011 03:35 PM
jam3s
Feb 23, 2011 04:45 AM
Corbyzz
Jul 10, 2003 10:31 PM
