R56 R56 Brake pad sensor mm
Old Jan 28, 2020 | 08:37 AM
Lipofskyphoto's Avatar
Lipofskyphoto
Rear brake warning came on on my R56 base and I have the red brake light.
The rear pads are at 6mm. I measured from the outside pads with my steele tool (super handy), but realize that the sensor is on the inboard pad and will measure that as well.
Does anyone know at what mm left on the pad, the two sensors are triggered? Anyone have a new sensor sitting around that they could measure the two stages?
I'm pretty sure that I haven't gotten the red brake light in the past at 6mm.
Thanks!
Old Jan 30, 2020 | 09:19 AM
vr4's Avatar
vr4
I would be interested in this answer as well.
Old Jan 30, 2020 | 10:51 AM
Lipofskyphoto
Really, all it would take is for someone who has a new uninstalled sensor to d a couple measurements.
Old Jan 30, 2020 | 06:06 PM
giorgos's Avatar
giorgos
Do cars for north America have different brake pad sensors than in Europe?
My (european, LCI) Mini just has a simple sensor (i.e. either on or off). The yellow light comes on when the car has reached the projected (i.e. calculated) mileage since the last counter reset, irrespective of pad status (as there is nothing besides the break pad sensor that could monitor pad wear). When the break pad sensor "fires", the red light comes on (whether or not the yellow one was on previously).
When I last changed the rear break pads, I had already driven about 600 miles since the red light had come on and the pads had about 3 mm or more left. The new ones (Brembo) had 17mm.
Edit: the 600 miles I did between the red light coming on and installing new pads were pretty much all driven in inner city traffic.
Old Jan 31, 2020 | 04:53 AM
R55_'s Avatar
R55_
Hello - about the same here, inner pad was 3mm, outer was 5mm (rear). On the other side they were both 3mm. Fronts were OK. Pads are cheap and easy to replace so I now just do so every 20 - 30,000 miles of mixed driving. The sensors are quite brittle and I usually order one on a free return basis in case I need it (we are a long way from any parts store).
Old Feb 2, 2020 | 05:54 AM
Lipofskyphoto
I checked the inboard rear right brake pad and, like what giorgos posted here, it had about 3mm left, if that (couldn't properly measure without removing it).
The two outboard rear pads have 6mm left, so the sensor was doing it's job.
I can't believe that the pad with the sensor is designed to wear more. If it were a sticky caliper piston, why would the outboard pad on the other side be 6mm?
Old Feb 2, 2020 | 06:10 AM
giorgos's Avatar
giorgos
It is normal for the inner pads to wear faster. However, 3mm vs. 6mm sounds like a large difference, I don't recall it being that much.
ijourneaux
Sep 19, 2018 11:55 AM
Powashiftin
Dec 23, 2011 06:50 AM
C2Ron
Oct 24, 2011 05:26 PM
AllanS
Tires, Wheels, & Brakes
Dec 20, 2009 04:47 PM
Blue Brummie
12
Apr 7, 2009 07:10 AM
