R56 2008 Mini Cooper AC issues with resolution.
Old Feb 20, 2019 | 04:08 AM
SOUNDAROUNDYOU's Avatar
SOUNDAROUNDYOU
Hello all,
I just recently worked through an issue with my R56 Mini Cooper Base Hatch. About two weeks ago I was on my way home from work and my AC started acting strange. It would randomly stop blowing cold. The following day, it stopped blowing cold completely. I ran through all of the usual checks making sure my fuses, relays, fan, and compressor clutch worked good. I even hooked a manifold up to it and verified that the system was not evacuated. It was turning into a real head scratcher. I pulled the codes and amazingly, it had 57 codes! Most of them relating to the buss system. Why I didn’t pull the codes first, is beyond me. The only codes relating to the AC system had to do with bad feedback from the outside temp sensor. I found, with research on this forum (thanks again!) that it was located in the right front behind the bumper. Well as it turns out, about three weeks ago, I hit a dead animal in the road and it ripped the bottom portion of my fender liner right out. Somehow, over the next week, the wire leading to that sensor wiggled it’s way out and started rubbing against the tire. The tire removed every bit of insulation and caused a short. I cut, soldered, heat shrinks, and taped the connection. I then cleared all of the faults and was back up and running.
After doing a bit of reading, my car has the automatic AC and heat system so it was keeping the AC from coming on. The car thought it was 32 below or something and was protecting the system.
I thought I would share this in case someone else has this issue. I searched but did not find this on the forum.
Thsnks!
Old Feb 20, 2019 | 06:58 PM
mkov608's Avatar
mkov608
The manual climate control system has the same problem, if the exterior temperature sensor is disconnected, the AC compressor clutch will not energize. The great part about the MINI is the engineers installed a separate temp sensor on the evaporator coil that reports to AC system computer module. I found this out when I was troubleshooting an AC problem. In my case, the blend air door wasn't closing all the way when set to full cool. My scanner can see blend air door position in percent. What I found was the temp control rheostat would not command full closed unless I pushed on it very firmly.
Old Feb 21, 2019 | 04:19 AM
SOUNDAROUNDYOU
Ah I see. I wondered if the info I found was a little skewed. Would you mind telling me what scanner you use? I am planning on keeping this car forever and will need something decent in the future. Thx!
Old Feb 21, 2019 | 05:20 AM
mkov608's Avatar
mkov608
Foxwell
Email elly@foxwelltech.com, and tell her Mark sent you. Ask for pricing on the NT520 Pro. I'm a beta tester, and forum members get special pricing.
DixonL2
Jan 4, 2008 08:34 PM
Monk Edsel
Aug 29, 2006 06:06 PM
Xanthus
Site Feedback
Aug 4, 2003 10:57 AM
