R56 Replacing whole seat with a heated one
Hy guys,
So I have been kicking around in these forums for awhile, but have not been able to find a consensus on an idea I've had. I live in Pennsylvania and it can get pretty cold here and one thing I regret not having is a heated seat. I have seen some of the retrofit kits to install seat heaters myself, but the complexity and potential danger has turned me away from going that route. Instead, I was wondering if I could buy a drivers seat that already has seat heaters equipped and swap it for my current drivers seat in my '08 R56S. Does the car by default have the proper connections and I could just buy a new row of buttons for the dashboard to turn it on? Or would the job be much more complex than that?
I appreciate all the help and input guys!
At a minimum your gonna have to change the control panel on the center stack. Probably going to need a new wire harness and perhaps coding. Some have done the retrofit. Just do search and you should see a number of posts.
It’s not plug n play and you’re going to spend a ton more trying to swap seats and figure out how to wire them up. Just get a seat heater kit and add them to your existing seats. There’s tons of YouTube How-To videos and you’ll learn a thing or two about your car. It’s not as difficult as it seems. I just picked up a kit off Amazon to install in a friends car. 2 seats for $55.
http://WATERCARBON Tech Era Carbon F..._E4TjCbRQS4A4V
There is no complexity with these kits. 2 wires and mount the heating elements.
Do it and you’ll be really glad you did.
If you need assistance, just PM me and I’ll be happy to help. I’m not local, but I’ve installed a bunch of seat heaters over the years.
First hand experience here.
I replaced the seats on my wifes countryman (non heated originally) with heated ones. I then replaced the dash comtroller that has the side buttons. Then, i ran 4 wires from the fuse box to the seats using newtis.info. after that, used NCS to code the fuse box and the controller to enable seat heating. That's it!
jhziiik2
Nov 22, 2016 07:08 PM
Interior/Exterior Can I retrofit OEM heated seats into not heated seat car ??
mp5999
Aug 26, 2013 06:20 PM
Interior/Exterior Heated Seats - is it possible to just have seat back and not whole seat?
jkling17
May 11, 2008 09:01 PM
Interior/Exterior Heated mirrors, and heated washer nozzles
AKIndiMini
Dec 12, 2007 03:34 PM
