R56 Engine Noise During Quick Turns
Old Dec 17, 2018 | 05:20 AM
Frixos's Avatar
Frixos
I have a 115k 2009 Justa. When I make a sharp turn, a most terrible noise comes from the engine bay. Sounds like things (metal?) that shouldn't rub against each other rubs against each other.
But when I check the oil, the stick says it's fine. But if I go ahead an add some oil, say half a quart, the noise goes away for a few weeks/month.
What do you say? What's making the noise? Any recommendations? Is it my lot to continue to add oil every few weeks?
Old Dec 17, 2018 | 06:00 AM
S-2013's Avatar
S-2013
First thought would be the front wheel bearings. Mine were making a metal on metal scraping noise only on right turns.
Old Dec 17, 2018 | 10:14 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
First thought I had was a strange coincidence about adding oil and noise going away. Second thought was if the dipstick is an OEM stick at the correct length and markings. Could you be running the car low on oil due to an incorrect reading?
I had some noises on turns that turned out to be ABS sensor loose and hitting the wheel on turns, but that surely wouldn't go away if I had added oil.
SonicTheMini
Oct 19, 2017 11:04 AM
damncajun
May 13, 2015 03:57 PM
flav
Jan 23, 2015 07:14 PM
Askika
Sep 5, 2014 07:41 AM
Notay
Aug 12, 2009 12:58 PM
