R56 HELP! Anyone have the cam alignment tool in PITTSBURGH?
I’m kind of up **** creek without a paddle. Starting my timing chain replacement and realize I ordered the wrong cam alignment tool for an N14 N12 Mini. I have a 2007 S, which I guess is neither of these. Is there anyone in Pittsburgh PA that has one I can use/rent today??? Please?
If your tool is anything like mine was, the part of the tools that locks the exhaust camshaft will need a section grinded off. It'll hit the turbo otherwise. Mine was for an N14/N12, but needed this modification.
yeah, that’s kind of BS you have to grind away a part to make it work. I was able to get it to hold the cams, but couldn’t bolt it down to anything. Seems like the cams were still able to move a tiny bit. I was able to get them aligned better with a straightedge and feeler gauges. So how much timing error does the ecm compensate for due to the flywheel pin and camshaft lock tool tolerance stackup? I’m probably within a degree of being perfectly timed
I had the tensioner installed instead of the tensioner tool, prolly why timing is vey slightly off. I will look at the tool again this weekend and time it again when my new cam bolts get delivered.
IIIIIII
Sep 16, 2014 10:32 AM
Carmichael
Chicago MINI Motoring Club
May 16, 2012 02:52 PM
fozworth
May 3, 2007 01:12 AM
IsItElectric?
Mar 2, 2006 04:15 AM
