R56 How much boost on 9:5 compression ratio
Old Feb 24, 2017 | 02:16 PM
timcluff's Avatar
timcluff
I just got done with my 2009 mini cooper s rebuild. I replaced the pistons with forged CP Carillo pistons and was wondering after I get done breaking the rebuilt engine in how much more boost can I add to the turbo?
Here is the link to the positions I put in, 77.5 mm bore and 9.5 CR
http://new.minimania.com/part/G2NME8...-Mini-Cooper-S
Old Feb 25, 2017 | 04:09 PM
BigBoost's Avatar
BigBoost
Are you going with a bigger turbo?
that's kind of a loaded question!
the idea with lower comp is being able to run safer higher boost leave's.
with that comp and a good tune you could run 1,4 bar all day long with no worry's/.
but like i sad its kind of loaded question .
Old Feb 25, 2017 | 04:11 PM
timcluff's Avatar
timcluff
I may eventually go.with a bigger turbo buy right now just the stock Borg Warner ko3 twin scroll but thanks for the insight
Old Feb 25, 2017 | 04:15 PM
BigBoost's Avatar
BigBoost
check out the jmtc GtD47mm or the frankenstein ko4.
ive been running the franksenstein ko4 for about a year with no problem's
an i just order up the jmtc gtd47mm from out motoring going to swap them out for this summer
Old Feb 25, 2017 | 04:17 PM
timcluff's Avatar
timcluff
I'll look into the franksenstein ko4. Is that a twin scroll as well or an open scroll?
Old Feb 25, 2017 | 04:33 PM
BigBoost's Avatar
BigBoost
Yeh it is a twin scroll.
its pretty much a stock turbo with a hybrid comp wheel an exhaust side.
Old Feb 25, 2017 | 07:10 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
You can run up to 30 lbs of boost on 9.5 to 1 pistons with meth injection. At 30 psi however it's recommended to either install a cylinder support system or Darton mid sleeves to close the open deck block. The CNC Werx CSS should be good for 400 HP and runs about $400. I'm currently running 1.7 bar on JCW factory internals with the X51 turbo and meth injection.
