R56 R56 2010 N47 Inner roll bar bushes front
Old Jan 10, 2017 | 01:03 AM
ryanlfc91's Avatar
ryanlfc91
All,
ive got some knocking noise under the passenger rear seat, believe its the innner roll bar bushes. Any idea how these come out? Seems rather tight down there. Does subframe need to be lowered/removed?
Any help would be appreicated.
Old Jan 10, 2017 | 10:44 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
When do you hear the knocking noise? You think it's the rear sway bar bushing, image below? If so, view this article here: http://www.pelicanparts.com/techarti...eplacement.htm. Be sure to check over all your other bushings for any signs of wear.
888.280.7799 | 6am - 5pm PST
Old Jan 10, 2017 | 11:35 AM
cerenkov's Avatar
cerenkov
Could also be the swaybar endlinks.
Old Jan 11, 2017 | 01:20 AM
ryanlfc91's Avatar
ryanlfc91
All, I believe its the front sway bar (ANTI ROLL BAR) bushes. When removing the drop link noise was gone. But no play in the drop links which makes me believe its the roll bar bushings. Does anyone know on removal instructions for these? Seems rather tight in that area.
Old Jan 11, 2017 | 08:33 AM
PelicanParts.com
Vendor
Do a quick Google search and search on the forum here as I believe there are a few threads around about individuals stating they lower the front subframe a little bit to gain access to the front sway bar bushings instead of removing the subframe completely.
For visuals, we do have info for the R56 and the subframe removal here: http://www.pelicanparts.com/techarti...me_Removal.htm. It might help with slightly lowering it as well.
Old Jan 11, 2017 | 07:13 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I would just just a box end and or ratchet wrench to remove the bolts for the sway bar brackets on both sides, then just slide the bushings off and replace.
We keep the bushings in stock
https://www.waymotorworks.com/oem-re...7-r58-r59.html
Old Jan 12, 2017 | 12:29 PM
miniuy's Avatar
miniuy
I can't access waymotorworks.com since some months ago.
Do you know why??
