R56 Rear fogs with reverse light?
I recently acquired a pair of 2013 Mini GP tail lights. After I put them on the car I had to take them off because of the lack of a reverse light. So i thought maybe just maybe there are some rear fog that have a clear section for a reverse light?
I have looked but I cannot not find anything. Does anyone know if that is a thing or do I need to sell the GP tails.
You'll have to use reverse lights for the 2011-2013 aero kit rear bumper.
https://www.northamericanmotoring.co...ke-a-list.html
Did the other lights (brake, rear, turn signal) work correctly when you put in the taillight? I would think that you'd get a lightbulb warning because the 2011+ rear running light is LED and your 2010 is checking for a standard bulb. A load resistor might fix it.
Yeah everything was working however the top half of the light was the brake light and the lower half of the light was reverse which is also red. I took them off in favor of the stocks one but if i can add the lower reverse and get it wired I would be happy
