R56 Boost gauge source
Old Aug 8, 2016 | 07:50 AM
1970Gizmo's Avatar
1970Gizmo
Boost gauge source
Hey guys.
I found a better/cheaper way of hooking up a boost gauge.
I installed the gauge on the dash and needed to find a source of boost pressure. I did a search and noticed everyone was using the boost adapter that fits between the pressure tube and the electronic boost sensor.
They seem to work well but there had to be a cheaper way.
I did some digging and found a boost tap fitting on ebay for $13.
It looked simple enough, and I didn't want to wait for shipping so I made my own. I simply got a nut/bolt and drilled a hole through the center. I then ground the threads off the end to allow the hose to attach.
Installation was very easy. I decided to put it just behind where the original boost sensor is. I loosened the clamp on the rubber hose and pulled it out of the way. I then drilled a hole and fed the adapter through the hole from the inside then put on a nut and washer. I then reinstalled the rubber hose and attached the gauge tube.
It works perfectly, cost basically nothing, and took only minutes to install.
Old Aug 8, 2016 | 09:03 AM
BigBoost's Avatar
BigBoost
BSH makes a boost tap as well?!!!
agordon1337
Sep 25, 2020 04:24 PM
dyeLucky
Mar 31, 2016 11:54 AM
themarques
Mar 30, 2016 07:05 AM
Lazcando
19
Aug 18, 2005 04:55 PM
KPiglet
Jul 22, 2002 10:41 AM
