R56 MCS Drinking Engine Oil!!
Old Jul 20, 2016 | 04:41 AM
Stokersrule's Avatar
Stokersrule
I am using a litre of oil per tank of gas!
I purchased a 2007 MCS recently with 190,000km (118,000 miles) & a bad exhaust valve on #1 cylinder. I replaced the bad exhaust valve and had the HPFP replaced by the dealer under the extended warranty. The car runs great, has lots of pep but uses a lot of oil.
I have read on this forum and elsewhere that high oil consumption in these cars is usually caused by the crankcase ventilation system built into the valve cover. From what I understand it is a sealed unit and not serviceable.
Has anyone had success by cleaning or flushing the internals of the valve cover to remove gunk or dirt that may be preventing proper operation of the crankcase ventilation system?
Any and all advice would be appreciated.
Old Jul 20, 2016 | 05:12 AM
cerenkov's Avatar
cerenkov
I believe that there is a diaphragm that tears, so you'll need to replace the whole cover.
Old Jul 21, 2016 | 04:13 PM
Jorge Perez's Avatar
Jorge Perez
I had bad smoke and the dealer replaced the valve cover. The diaphragm went bad, oddly, I started with the blue smoke again.
Does your whistle if you let run at idle for a long time? say 10 mins
Old Jul 22, 2016 | 07:43 AM
Stokersrule
I've never noticed any whistle.
Is there s way to test the diaphragm in the valve cover?
Old Jul 25, 2016 | 11:25 AM
NB Cooper's Avatar
NB Cooper
You can test to see if oil is being vented out the back vent line by running a substitute line to a catch can and observing to see if oil accumulates in the can. This will tell you if it is the source of the issue.
Or if you wish, you could simply install one of these from ECS.
https://www.ecstuning.com/News/MINI_...Options_19333/
Once again, it will tell you if the issue is oil venting out of the PCV but it will contain the oil and perhaps buy you some time before you replace the valve cover, if that is the issue.
Old Jul 25, 2016 | 03:52 PM
Jorge Perez
Im going to try this out with my brothers smoke tester
Rich.Wolfson
16
Jan 28, 2020 02:58 AM
Autotragic
Apr 26, 2016 05:22 PM
Croach08
Mar 22, 2016 08:06 AM
Bponce23
Mar 21, 2016 03:12 PM
NYTransplant
Mar 13, 2016 11:10 AM
