R56 Hood Release Broken - Cannot Open Hood!
Old Jul 8, 2016 | 03:51 PM
HavocVsChaos's Avatar
HavocVsChaos
I need help! Hood release has failed. The cable is slack AND the white cable 'stay' is exactly where is should be, see attached pic. Can anyone help me? I really want to open my hood!
2008 R56S N14 Manual
Old Jul 8, 2016 | 07:59 PM
Tim H (WarDoc)'s Avatar
Tim H (WarDoc)
Pull the inner fender plastic and manually release it.
Old Jul 4, 2018 | 01:09 PM
MINI_with_a_long_name's Avatar
How??
I'm currently having the same problem with my '12 r56 S, I have taken both tires off and I do not see any release or even the latch mechanism itself... A more descriptive explanation would be appreciated
Old Jul 5, 2018 | 08:41 PM
Ive's Mini's Avatar
Ive's Mini
I had that happen to mine. The way you need to do this is from underneath. As you look straight up around the areas of the latches, you can see where the lever that is controlled by the cable is located. I was able to take a long rod and move that lever and pop the hood. You do not need to take anything apart other than go from underneath. You need a good light and take your time. It took me quite some time but I did get it eventually.
speedkills66
Sep 12, 2016 07:37 PM
3lusive
May 4, 2016 08:25 PM
TWISTER
Apr 26, 2016 09:53 AM
blonda
Apr 25, 2016 08:15 AM
Qbert
Apr 24, 2016 03:03 PM
