R56 What transmission do I have?
Old Jun 25, 2016 | 09:14 PM
farside847's Avatar
farside847
I know dumb question, but I could not find an answer.
I have a stock 2008 Cooper S with a manual 6 speed transmission. I am planning to replace the fluid in the transmission and got myself a few quarts of the Red Line MTL 75W/80 oil from Pelican Parts.
But right there on the receipt it says that this oil should not be used on the G56-55BG transmission. How can I tell what I have? The window sticker just said "6 speed manual Getrag transmission"
thanks!
Old Jun 25, 2016 | 09:47 PM
Fly'n Brick's Avatar
Fly'n Brick
Only dumb questions are like "What time is the midnight buffet?"
The G56-55BG transmission is the Getrag and one solid 'cast iron' gear box it is. Best recommendation is leave it alone unless you tend to grind gears then use only BMW/MINI fluid.
We've got just over 100K miles on the factory gear box fluid and no worries here, original clutch and TO bearing too.
Old Jun 25, 2016 | 11:00 PM
farside847's Avatar
farside847
glad I asked...
According to this:
http://new.minimania.com/MINI_Cooper...mission_Fluids
I have the GS6-53 BG/DG 6-SPEED (GETRAG G253). But it looks like Red Line is not recommended for it.
I was only changing it because I am at 90k miles and read it was a good idea. Guess not!
Old Jun 26, 2016 | 07:14 AM
Fly'n Brick
When it comes to the Getrag gear box, some old saws come to mind:
'If it works, don't fix it.'
'Just because you can doesn't mean you should.'
'Let sleeping dogs lie.'
...and I'm sure the list can be added to. Treat it kindly from the cabin and you'll get lots more miles of exceptional motoring.
Old Jun 26, 2016 | 07:34 AM
bavmotors's Avatar
bavmotors
I disagree, change it before it is broke. If it's broke its too late to add fluid...Ask me how I know.
kyoo
Aug 6, 2021 07:54 AM
goan
Mar 25, 2016 03:58 PM
1004ron
Mar 22, 2016 09:39 AM
1004ron
Mar 21, 2016 10:14 AM
MINI-Madness
General Discussion
May 26, 2002 11:45 AM
