R56 CC-ID 029 half power light
Old Apr 28, 2016 | 12:56 AM
Nick Royer's Avatar
Nick Royer
I just recently got my ecu manic tuned, they sent me the ecu in high power mode because the switch was going to take longer to get, well yesterday I got the switch and I set the map to stock and drove around with the SPS switch still in and adjusted on the fly not knowing that you were supposed to set the switch to the map you want plug it in then remove it. Well know I have a half power cell and I'm getting the code cc-id 029 which is the code for the HPFP the car is running normal is this code for setting the tune back to stock or from adjusting the map while driving or is it actually my HPFP? I tried resetting the ecu by unplugging the battery for an hour but the half power cel still is there
Old Apr 28, 2016 | 07:55 AM
Sstrickstein's Avatar
Sstrickstein
Contact your tuner.
Old Apr 28, 2016 | 08:23 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If the problem arouse after you got the tune, I agree with above, I'd first reach out to them and see what they might have to say. Are there any symptoms associated with the code? This individual HERE was not so lucky with the associated code, start at post #8. This one HERE was a DV issue. Hope you get this figured out. Good luck!
888.280.7799 | 6am - 5pm PST
Fiveostang
Apr 17, 2016 08:53 AM
Cmv138
Apr 11, 2016 06:18 AM
Russter500
Apr 3, 2016 07:37 PM
aford89
Mar 30, 2016 05:52 PM
ahurvitz
Mar 30, 2016 09:57 AM
