R56 Can someone help me out here? Coolant leak
Old Apr 12, 2016 | 12:58 PM
Daniel Li's Avatar
Daniel Li
2011 Mini Cooper s ,
I can see blue coolant is leaked on the silver cap thing ,What is this part called ?
What should I do ?
Daniel Li's Avatar
Daniel Li
Old Apr 14, 2016 | 02:48 AM
minibeer's Avatar
minibeer
I have the exact same leak. That's the temp sensor, it has an o-ring around it. The plastic sensor comes straight up out of that metal housing after you release the 2 tabs on the sides. Remove the old o-ring, install the new one, insert it back into the hole. It's super easy, just make sure the engine has completely cooled - like overnight - or you will get a face full of coolant.
Old Apr 14, 2016 | 08:25 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Have you had the thermostat replaced yet on your R56? The new thermostat design comes with the temp sensor integrated into it, which renders that sensor useless. You can see the new thermostat below. That o-ring in the sensor is prone to leaking. Many people will plug that hole permanently once they replace their thermostat so that it does not leak.
http://www.pelicanparts.com/catalog/..._pg1.htm#item4
888.280.7799 | 6am - 5pm PST
Old Apr 14, 2016 | 01:52 PM
Daniel Li's Avatar
Daniel Li
Thanks. Engine light is on. COde reader as " thermostate heater Control circuit/Open"
was yours the same issue?
Old Apr 14, 2016 | 01:56 PM
Daniel Li's Avatar
Daniel Li
Do u have specific brand name for the tem senor and where i could get it?
Old Apr 14, 2016 | 02:01 PM
PelicanParts.com
Vendor
P0597 sounds like you have a bad thermostat. Read over this thread HERE and HERE for info. Thermostat and adapter lead for your R56 is HERE. Once you determine this is your fix, you can take some RTV and seal off that section permanently so that it wont leak from there again. As I posted above, the new thermostat sensor is integrated into the thermostat housing.
moremini
Apr 20, 2016 07:08 AM
bda211
Apr 5, 2016 09:11 PM
LuckyClubbie
Mar 30, 2016 11:20 AM
JWA
Mar 20, 2016 04:29 PM
