R56 OPT7 LED base model headlight bulb replace
Old Feb 28, 2016 | 07:56 PM
cargusjoh's Avatar
cargusjoh
Hi,
I have OPT7 CREE 80w H4 9003 LED 6000k replacement headlight bulbs I installed and they work great except there is a gap in the light pattern. Right side is perfect. Light just in front of the car, along the far right side, and down the road quite a ways. Left is fine except a considerable black rectangle on the left mid way out, and far out slightly into the center. If starts probably 30 feet forward, then is crisply cut off. I don't think I can adjust the left light to the left much or the far center part will blind oncoming drivers.
Anyone encounter this? What did you do to resolve t?
Old Feb 28, 2016 | 08:15 PM
bcriverjunky's Avatar
bcriverjunky
You might have to rotate the bulb in the base. Compare it with the other side
Old Feb 29, 2016 | 12:26 PM
MiniSkoon's Avatar
MiniSkoon
I had to return these. Too much glare for on coming traffic if you don't have a projector lense and I couldn't get the beam pattern right either. They flickered for a few seconds on start up and are not DOT legal. I liked the color a lot but just didn't work out. Went with PIAA's xtreme white. Better than stock and are DOT legal.
Old Feb 29, 2016 | 01:20 PM
cargusjoh's Avatar
cargusjoh
Ahhhh. I don't have projector lenses. Did not know they were not DOT legal. Thanks for tip on the PIAA
Flboy10
R61 :: Paceman Talk
Oct 27, 2016 01:53 PM
Flboy10
Mar 1, 2016 05:53 AM
PelicanParts.com
Feb 10, 2016 10:52 AM
banyan
Jan 31, 2016 06:01 PM
PelicanParts.com
Jan 25, 2016 03:19 PM
