R50/53 LED upgrade for stop and tail light question
Old Jan 30, 2016 | 09:05 AM
banyan's Avatar
banyan
when upgrading the stop/tail lights to LED, do I need to add a load resistor as well? I heard that without the load resistor, the cruise control might not work as it uses the load current from the brake lights for trigger (ie LED uses lower current than regular bulbs)
Those that have done such an upgrade, can you confirm?
thank you
Old Jan 30, 2016 | 10:20 AM
rkw's Avatar
rkw
An R53 doesn't have bulb out detection, and no load resistor is needed for stop/tail lights. However, the turn signal will hyperflash without a load resistor.
I've never heard that about the cruise control, and it makes no sense. It would mean the cruise control won't work properly if the brake light bulb burns out. I'm sure that the cruise control uses the switch at the brake pedal.
Old Jan 30, 2016 | 10:40 AM
banyan's Avatar
banyan
makes sense....thank you.
Old Jan 30, 2016 | 12:31 PM
banyan's Avatar
banyan
ok. just installed the LED brake/tail lights. They look brighter, but the tail lights flicker. The flicker goes away when the brake lights turn on (when pressing on the brakes). do you think the load resistor will resolve the flickering?
Old Jan 30, 2016 | 12:49 PM
Vkng's Avatar
Vkng
Did you get lights that are designed as tail and brake lights? Sounds like they are single brightness and are being under driven without the brakes.
Old Jan 30, 2016 | 12:55 PM
banyan's Avatar
banyan
Yes I beleive so. I am using super bright Leds - 1157-R45-T Red
Old Jan 30, 2016 | 01:37 PM
Khai's Avatar
Khai
The only way I have been able to solve flickering led lights is by running power through a relay directly from the battery. Try hooking the lights up to the battery and see if it flickers. I have tried to solve this problem on dodge Rams but it only worked for me when I make my
Own circuit.
Old Jan 30, 2016 | 03:02 PM
rkw's Avatar
rkw
I would say yes, a load resistor will stop the flickering. It sounds like a low level current is running through the circuit even when no brakes are applied, not enough to be visible with a filament bulb, but just enough to make an LED bulb flicker. It doesn't have to be a full load resistor that simulates a standard bulb, but a low value resistor that is just enough to stop the flickering. Also, if you use a full load resistor it will draw as much power as a regular bulb.
Khai's suggestion with a relay will also work, but takes more effort. If you go with a relay, you can even use standard bulbs because the bulbs will completely bypass the BC1.
Old Jan 31, 2016 | 06:01 PM
banyan's Avatar
banyan
good news...i notice that once warmed up the flickering disappears
Flboy10
R61 :: Paceman Talk
Oct 27, 2016 01:53 PM
banyan
Jul 10, 2016 05:03 PM
Eurothrasher
Mar 17, 2016 02:59 PM
Flboy10
Mar 1, 2016 05:53 AM
jeffl
Jan 26, 2016 10:20 AM
