R56 Cold Weather Mini Water Temp Help
Old Jan 4, 2016 | 08:05 PM
no1jones's Avatar
no1jones
I have a scanguage II hooked to the 08 MCS (as I have had since May). Before my Manic tune she would run close to 200-210 F according to scanguage. After tune she hovers around 175-185 F. Now the weather in Iowa has turned cold and I noticed today that normal operating temp of 175f but when I stopped at the ATM and idled for that time it dropped to 155 f. As soon as I took off it went right back up. I did a test a couple times and it did this every time I let it idle for 5 minutes or so. Is this an issue or normal for a 08 MCS in 25f weather? No codes, no leaks that I can see currently (or on my garage floor). Thanks in advance for the help.
Old Jan 5, 2016 | 02:51 AM
Eurothrasher's Avatar
Eurothrasher
How does the manic tune drop coolant temps ? Does their tune trick the thermostat to hold it open longer or all the time telling it temps are higher than actual ? I ask only because I don't believe the RMW tune does this as ScanguageII in my friends RMW tuned R56 reads normal operating temps like any other...
Old Jan 5, 2016 | 05:58 AM
miniuy's Avatar
miniuy
I never heard that a tune changing the coolant temperature!
And that low coolant temperature when the vehicle is idle on a very cold weather is totally expected (the car is not working hard).
As well as a vehicle that is idle on a very hot day will have a higher temperature (the water is not being cooled by the wind generated when running).
I do not see problems in the behavior mentioned.
I still drawing attention, to the tune that changes the coolant temp value!
Old Jan 5, 2016 | 06:19 AM
Gipper's Avatar
Gipper
I have a Manic tune, and yes, it lowers the temp to around 180 degrees F, give or take. It's not an issue, even at 9 degrees this morning. Still plenty of heat, and the lower temps will help the engine live longer and make more power.
Eric
Old Jan 5, 2016 | 06:33 AM
no1jones's Avatar
no1jones
Thanks for the replies. I don't know all the ins/outs to the Manic Tune just know that after I got my computer back it ran cooler than it did before. I have the 2+ and run on map B most of the time.
Glad to hear there doesn't seem to be a concern for the lower temp reading. I do still have all normal heat inside and such, but had never noticed it before or on any other car I have ever own. Then again this is my first 1.6l turbo car.
robertcoyle
16
Dec 28, 2015 10:31 AM
SneedSpeed
Dec 15, 2015 01:13 PM
raday
Dec 11, 2015 08:39 AM
ZachBlev
Dec 10, 2015 07:20 AM
Ambient Thermal Management
Dec 8, 2015 10:56 AM
