R56 Should I replace my Timing Chain Assembly?
Old Oct 28, 2015 | 12:45 PM
Miniwaukee's Avatar
Miniwaukee
I have a 2010 MCS, and had the timing chain tensioner replaced in 2013 under warranty. I brought it to the shop last week and he asked if I ever had the assembly replaced. He said that the belt still has tension, but he has heard of people replacing the assembly as a precautionary measure. There is a weird scraping noise coming from the motor, but I don't think it is related to the timing chain. Should I wait for symptoms or change it just to be safe? Thanks!
Old Oct 28, 2015 | 04:30 PM
sub3622's Avatar
sub3622
If you can post a video so we can here the noise that would be helpfull.
Old Oct 29, 2015 | 05:38 AM
I would pinpoint the scraping noise , it might not be related to the timing chain. Since yours was just replaced. Now a belt scrapping , that might be the serpentine belt of the tensioner on the main belt, not the chain. Post up a video.
Old Oct 29, 2015 | 05:49 AM
Helix13mini's Avatar
Helix13mini
A timing chain will not typically produce a scraping noise. When he said belt, he's probably talking about your belt train, not your timing chain assy. The most common belt train sound would be a squealing vs. a scraping.
Old Oct 29, 2015 | 12:20 PM
Miniwaukee's Avatar
Miniwaukee
Ok I'll see if I can post a vid tonight
Old Oct 29, 2015 | 02:18 PM
z3ds's Avatar
z3ds
If you have a big flat head screw driver you can use it to pin point the sound. Place the tip on certain spots on the engine and put your ear on the handle to listen.
DRoc7822
Nov 13, 2015 06:37 AM
htroberts
Nov 9, 2015 08:31 PM
Bryan Thomas Snapp
Oct 28, 2015 09:52 AM
F55MidnightBlackCooperS
Oct 28, 2015 07:50 AM
Kid_Organic
R60/R61 Stock Problems/Issues
Oct 27, 2015 10:06 PM
