R56 2012 MCS Scangauge 2 boost question!
Old Nov 18, 2014 | 08:08 AM
Mumuti's Avatar
Mumuti
Hello!
I wanted to ask you a question, recently bought me a mini cooper s 2012 and install a scangauge 2.
the question is about the reading of the boost in psi, it is normal that are in neutral if I speed up the boost does not increase? I speed up thoroughly and not mark more than 0.8 psi, when I first, second, etc gear accelerating moderately boost does not increase neither... unless they speed up thoroughly then climbs.
it is normal that at first accelerating full raise the boost up to 8 psi or 9 psi, then second climb to 11 psi and third climb to 13-14 psi? not should have the same psi on all the changes?
Best Regards
Old Nov 18, 2014 | 12:50 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Yes the ECU limits torque in first and second gear. It does this by limiting boost. It's intended to reduce tire slip and increase longevity of the power-train.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
FrostyFox
Oct 28, 2015 02:06 PM
Colt45Magnus
Aug 13, 2015 11:18 AM
nomar116
Aug 10, 2015 11:24 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
