R56 Hood (bonnet) issue with safety latch
Old Nov 9, 2014 | 06:20 AM
potxoli's Avatar
potxoli
Hi,
I was going to change to oil today on my 2007 mini cooper, but I can't open the hood. The latch inside the car works well and the hood pops about 1" or so, but the safety latch is firmly stuck. When I press on the lever with my hands I can't budge it, even a fraction of an inch. I tried prying it with a small screw driver and that did not work either.
I tried searching but most people seem to have problems with the cables to the interior latch and my problem is with the finger latch on the bonnet.
I tried lubricant, but did not work. Is there something obvious I'm missing here?
Thanks!
Old Nov 9, 2014 | 12:44 PM
potxoli's Avatar
potxoli
Well I finally got it open. PB Blaster and some patience did the trick. It had rusted through...
Old Nov 10, 2014 | 02:23 PM
Slave to Felines's Avatar
Slave to Felines
I think that means you don't check your oil nearly often enough...
Old Nov 11, 2014 | 05:41 AM
Check those latches , they an take a pounding as they are directly in line with crud and road salt that comes through the grille and between the gap. I always tell people to spray them with penetrating fluid as much as possible. We have a refresh kit if you need it. Seem to be the 07 and early R56 models that are seeing this problem pop up like the Gen 1 MINIs. inside the cables can rust and the latch Handel will bend the pull tab if you pull to hard with stuck latches.
51232751378KT Hood Release Kit
http://www.ecstuning.com/News/MINI_R56_Up_Hood_Release_Kit_2007_2008_2009_2010_2 011_2012/
Knuckle14
Aug 26, 2015 08:10 PM
Mikal68
Aug 13, 2015 07:10 AM
clintmeister
Aug 12, 2015 11:11 AM
bctf1
Aug 6, 2015 12:55 PM
